Electric water pump kits LB7, LLY, LBZ and LMM
maine04max
Dec 11, 2008
1,009
I can tell you I have killed 2 welded oem water pumps ,both in less than 300 ( street) miles from when my twins went on . I also dont rev my motor very high
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
I just installed this kit on my truck and everything fit perfect and was pretty straight forward to do. I mocked the pump up backwards for some reason and that's when I took this pic.
ZR1160
TT Dmax Junkie
Jan 12, 2007
221
Eastern Canada
It would be nice to have a pressure gauge on it to be sure it working, I'd rather watch a pressure gauge then temp gauge......but a very nice piece!
CurtisEmery
Mar 21, 2008
486
Ontario, Canada
How would I know if I had twisted my water pump shaft off. I have a feeling I may have done this on the weekend. I am seeing no coolant flow out of my return for the charger. Has me wondering?
maine04max
Dec 11, 2008
1,009
the easiest way to tell if you have a water pump issue is to pull off the lower hose off the pump. then use a bent coat hanger or something and see if you can move the impeller on the pump . when you look up inside the pump you can just barely see the impeller , if you can move it then its broke . could be either side ( gear or impeller ) .
xcablb7
Feb 8, 2009
536
Fall River
Or you check like me try driving it and it overheats and blows a headgasket lol, I don't have this kit but I went electric works fine for everyday street use no issues yet bout 5000 miles
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
Says hasn't been tested for street use ? I've read a few of us on here have used them on DD's , right ?
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
I drove mine around quite a bit with electric pump and fans and everything seemed fine. My truck also gets extremely hot going down the track and it doesn't seem to take long at all for it to cook back down.
