DPF damage
rickr2007
Dec 22, 2021
2007.5 LMM
I was rear ended and my exhaust system was damaged.
The small tube to the rear of the DPF is broken off. part # 25799002
I have NO codes, truck is running fine but I have been told the truck will eventually go into limp mode.
Part has been discontinued. Trying to get local diesel tuner to do a DPF delete but he will NOT work on truck due to it being an insurance claim :(
Should I expect limp mode?
THANKS for replies
1,728
that's for the differential pressure sensor. it's one of the metrics used to monitor the DPF and determine when to do a regen. if the rear is broken you may be able.to get by since that measures the pressure after the DPF witch should always be less.
is there any reason you couldn't just put another hose on it from the parts store?
rickr2007
Dec 22, 2021
2004lb7
THANKS hope you are correct
I found the part online
Broken part is the flared fitting on the end. Stainless.
I will keep on driving locally and see what happens
rickr2007
Dec 22, 2021
Thanks for the replies
Update; Part (25799002)is discontinued and I cannot find any "Old Stock"
I used PB Blaster and the "Heat Wrench" to get the flare fitting out of the bung and I think the bung is damaged :(
Is the insurance company going to "Total" my truck because a $78 part is not available???????
rickr2007
Dec 22, 2021
2004lb7
I have spent 4 hours trying to find parts and the Differential Valve (2799002)and DPF filter (15909020) are both discontinued and not superseded. GRRRRR!
1,728
rickr2007
Dec 22, 2021
THANKS for the replies
Darkness- East Tennessee
DNDJ Thanks for link. I think my DPF is damaged also, getting diesel exhaust smell in cab.
SFCJones I will keep that in mind. THANKS for your service!
Following up with Body shop and Insurance this week. I am "Building" and cannot go without a pickup. Looking for a new High Country, my LMM might be "For Sale" soon :(
