These still retain the factory stroke of the pump so their output is the same. The stock pump sees restriction once you hit the 3,000 rpm mark typically. These pumps are just modified to get the max output of the pump above 3,00 rpm so there is no dropoff when you get into the higher rpm range. They're good for 600-650 or so depending on supporting modifications to get you there.
Exergy.Ok. Good to know.
I bought a used one that supposedly was on a puller for about 25 hooks then buddy went bigger.
Should I get it tested before putting it on and if so where would you recommend I send it?
It's been sitting for a year.
So is twinning a 12mm with a stock LBZ not a good idea on the Nova with the 3k rpm issue? That's what we are running now with 250% exergys.
