Crank no start, has fuel pressure.
Dante2795
Completely stumped here. Lb7 broke a crank, we swapped in a complete running engine back in it. Truck builds higher rail pressure than desired. It’s reading 9k psi cranking. But will not start. I am getting P0374 as well. Swapped in brand new cam and crank sensors and nothing. All wires appear fine. All grounds are good. Any ideas?
Dante2795
Now it’s throwing p1500 and actual rail pressure is jumping 12k cranking. Rpm ranges from 90-200rpms
ZeroGravity58
1,382
46
Maryland
I'd check all the wiring, the ficm won't fire the injectors without a proper cam signal
PO374 Code means the engine control module (ECM) replicates the signal received from the crankshaft position (CKP) sensor. This signal is sent to the fuel injection control module (FICM) through the engine speed signal circuit. The FICM uses this replicated signal to generate injection current and control the recharge of the fuel injection high voltage circuits. When cranking, the FICM has full control of the fuel injectors. The only input the FICM uses at this time is the engine speed signal from the ECM. The FICM monitors the signal along with the injection request signals from the ECM after the engine is running. If there is a problem with this signal, a DTC could set.
