LMM: crank gear reluctor wheel
CRAWLEN
134
Soo, i made a stupid move (no clue why I did this) but I pulled the reluctor wheel off the crank gear.
So my question is does anyone know where I can get the 2 alignment pins from, or atleast know the size of the holes so I could just buy some dowel pins to do the job
CRAWLEN
134
any luck ? thinking of going to get some roll pins that will fit and do it that way but feel like that will allow movement still.
CRAWLEN
134
Instead of starting a new post I might aswell bump this one again.
Does anyone know where I can buy the 2 knock pins to align the reluctor wheel to the crank gear ?
It looks like the gear side is 5mm as I have used 2 5mm drill bits and there snug. But it seems the reluctor wheel has bigger holes as I still get a bit of movement. Is it a taper on the pins gm sells or stepped maybe ?
