Connector id
AJH
257
Memphis TN
Can anybody identify this connector? Its under the column. I’m doubting this is how the truck left the factory 16 years ago.
dndj
Boost!
Apr 13, 2019
302
33
Oregon
Doesn't look stock. :roflmao:
I did a quick scan through the FSM didn't see a 6 position single row connector right offhand. What does the wiring connect into? If you could trace it back to some other connection that would help tremendously.
KyleC4
470
Bay Area
Clutch position switch. Someone jumped it so they wouldn’t always have to have the clutch pedal depressed to start the truck
AJH
257
Memphis TN
:thumb:
I’m gonna say you are dead on the money. I noticed that but being the only zf6 truck I’ve ever been around wasn’t really sure if it was wrong.
Edit
Would this cause the parking brake light to always stay on?
KyleC4
470
Bay Area
I don’t think so. That should only be a single wire on the parking brake itself. If no codes of course. And I think only other thing is brake fluid level switch that will turn park brake light on with no codes. I could be wrong though.
