Bad Injectors?
Welder
May 9, 2020
14
Being told by Dealer I have 2 bad injectors. Could Cleaning help and if so how/what to use. I noticed no miss they told me a month ago I had an injector going bad. Took back to dealer last week for different issue and check engine light came on as I pulled in now they say I have 2 bad injectors. 2011 GMC
Welder
May 9, 2020
14
1,721
Need a little more information. Balance rate are off? Too much return? Leaking? Give us something more to work with
If you want to try some cleaners. The GM injector cleaner along with the process is supposed to be about as good as it gets. Otherwise just run some name brand stuff in the tank. Most of the time it only gets you a little more life and you may as well start saving up. Not that it is hard to replace but be prepared to change them anyways
Ron Nielson
684
114
Berryton, KS
It would be helpful to know what tests were run to determine that 2 injectors are bad. I'm assuming you know which 2 they are? Specific results on the bad and the good ones may tell you a lot. .
Welder
May 9, 2020
14
Will see if i can get info
Welder
May 9, 2020
14
Balance rates 1/-.42, 2/.94, 3/-.31, 4/.53, 5/-1.63, 6/-.06, 7/.33, 8/.55
Welder
May 9, 2020
14
