Allison 1000 Dipstick depth
Mogman
341
17
Papalote, TX
I can feel the dipstick bottom out in the pan just before it gets fully inserted is this normal? 2008 LMM, I did remove the tube and the dipstick would fully insert without any resistance so I am pretty sure it is bottoming out
Mogman
341
17
Papalote, TX
So how does one go about "calibrating" a dipstick, I had to cut both the tube and stick down for this application and just copied the error that was already there when I started.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Maybe this will help? Looks like according to the latest post the full oil point is 2.5 inches below the block.
Bdsankey
3,905
1,074
Neenah, Wisconsin
Easiest way would be to insert an uncut tube and dipstick then measure the depth below the pan rail. You could then mimic that with your cut version.
Mogman
341
17
Papalote, TX
Thanks, that's what I started with, also that would be pretty difficult now that it's stuffed in the chassis, for now I will just assume it is reading low and bring it over full a little bit
