LLY: 7.xx's stock fuel/air lly possible?
thomasreynolds90
Aug 18, 2015
13
I'm curious if anyone has broken into the 7's in the 1/8th with stock turbo and injectors and if so how far?
Sent from my SAMSUNG-SM-G870A using Tapatalk
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
My truck went 8.08 stock air and fuel. No weight reduction. I'm in an LMM though.
thomasreynolds90
Aug 18, 2015
13
That's pretty impressive. I'm trying to keep from using additional power adders though,I'd just bite the bullet and go with a larger charger before I sprayed it. The last few runs I made were 8.4's and I've since put on a centerlink brace,Traction bars and a transfer case brace. I'm hoping that'll shave some time off my 60ft and maybe a little overall once I launch harder.
13,597
626
A 7.99 would be equivalent to about a 12.5-12.6 in the 1/4. Plenty have gone that fast with stock fuel and air.
I also went 11.75 in the van on fuel, but that was some pretty serious weight reduction.
thomasreynolds90
Aug 18, 2015
13
Right on,I'm going to take off roughly 400lb between the tool box,spare and hitches. Realistically that should put me between 8.2 and 8.1 I'd think. I was debating manifolds,up pipes and a batmowheel to help get me there but that would cost almost as much as a turbo lol.
Who's tunes do you have?
thomasreynolds90
Aug 18, 2015
13
Are the vans lighter to start with?
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Dont need any of that crap.
13,597
626
I weighed before I did any weight reduction, and it was right at 6400 lbs with me in it. After removing everything I did, it was almost 1100 lbs of weight reduction.
thomasreynolds90
Aug 18, 2015
13
That's some weight loss.lol
Burn Down
Sep 14, 2008
7,093
Boise Idaho
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Mark@Danville does all my tuning. You don't need anymore engine/turbo/fuel parts to hit your goal. Suspension setup and dialing in tuning. (You could have a weak cp3 or injectors holding you back)
1,598
7.7s here
It is not easy to do, but definitely possible. Weight reduction helps a lot.
