48re conversion with a SCS transfercase in a 07 classic
Sterling Diesel
Aug 12, 2018
14
New Caney, TX
Looking for any ideas on where to get wheel speed from since factory tcase was removed and scs case was installed. Truck needs to see rear wheel speed, any ideas on where u can run the factory rear speed pigtail wires to get a signal from!? Any help is greatly appreciated
Sterling Diesel
Aug 12, 2018
14
New Caney, TX
48re conversion with scs tcase speed sensor
Sterling Diesel
Aug 12, 2018
14
New Caney, TX
The truck has a full manual valve body in it currently, tied in to the 48re ang got it to read wheel speed, everytime key is turned off and back on you have to clear the abs codes for rear speed sensor. The moment you clear it it goes back to normal. Im thinking the sensor in 48re vs factory sensor in the tcase are two different operating voltages
