2012 Lml Silverado 3500 HD front brake question
mopar440cu
Duramax Newbie
Jul 14, 2018
14
FL
Morning Guys,
I have a question about the front disc brakes on my 2013 3500. I have the truck up on jack stands checking everything out and went to turn the drivers side wheel and it will only spin a little, not like all my other Dodge 3500's. I would think I should be able to spin the wheel more just like my other trucks. What do you think this may be? Rotor sticking possible? I will take it down off the stands and drive it around and see if there is a build up of heat at the hub with my hand and let you know. I am trying to figure out this newly acquired work truck I just purchased. Thanks for any suggestions.
ikeG
Oughta Know Better
Apr 19, 2011
2,428
128
Western PA
www.facebook.com
You could remove the caliper and tie it up, then put wheel back on and try again. This will verify if it is the brake system or not.
Sent from my XT1585 using Tapatalk
