2008 lmm tuning questions
Mar 6, 2021
Prescott Arizona
So I sold my 06 lbz got this lmm lift pump,4” deleted exhaust, dsp5, and a v2 autocal Idaho rob all this was done when I bought it thing is no position on the dsp5 feels any different?. Gas mpg sucks only 15mpg truck has a 6” rcd lift on 35s btw any idea if the tunes even are loaded?.
monster50iii
329
You won't get mpgs with the lift and tires fwiw..
If you have the autocal plug it in and re-download the dsp5 file? Worth a try..
N2BRK
1,900
216
Many times it's a poorly installed DSP5 switch. Check the wires and check to make sure that they are fully inserted. I've fixed 3 in the past year and I'm not even a mechanic, LOL.
1,731
You can also log the switch position or voltage and see if it is working according to what the ECM sees
08lmm72mm
528
164
Saskatchewan, Canada
What kind of shape are the injectors in and is there any boost leaks? What the calculated fuel rate at idle? Worn injectors and a minor boost leak can make these trucks seem like each tune isn't much different from each other. My balance rates were good the cfr was 6-8. I put new sticks in at the cfr is 11-12 and I can tell a huge difference in power again between tunes.
Mar 6, 2021
Prescott Arizona
Not sure I only have a autocal to read anything right now and it won’t show rates. But with the fass pump actually working I can tell the difference some now but I believe there stock trans tunes
