50257 submitted a new Showcase Item:
2004 Gmc 3500 dually
Read more about this showcase item here...
EFI Live v2 - 5 position DSP. S&B Turbo mouth piece. MBRP 4" down pipe back single side exhaust. Cognito upper control arms and leveling kit. Bilstein shocks. CM Truck Beds: SK Model - Modified to cover wider 20" wheels. Fuel 20" Cleaver dually wheels with Michelin 275/65/20 LTX A/T2 tires.
2020 Updates:
Cylinder heads - Complete LLY Head Gasket Kit with ARP Head Studs and Mahle Grade "C " Head Gaskets - HSP Compound Kit: S475 / 96 / 1.15 cast wheel over stock LLY turbo - 2" up-pipes - Hot side pipe - High flow driver side exhaust manifold - Fuel rail plug - FASS Titanium Signature Series 165 GPH Lift Pump - LDS - New Bosch 45% over LLY injectors - S&S LBZ SuperSport CP3 pump - Edge Insight CTS2 Monitor with EGT probe - Merchant Automotive water pump kit - SDP Built transmission with billet triple disc converter, Billet Stator & Billet C2 hub - Danville tuning.
