2002 vs 2003 allison.
222
yes, just swap over the cooler line fittings in the bellhousing from the trans you pull to the trans going in.
15,444
95
Disneyland, CA
'03 was a change over as far as the cooler fittings. Early '03 used the 3/4 by16 fittings ( same as '01/'02 ) and the late '03 used the 7/8 by16 fittings which are the same as '04 through '19. Adapter fittings are available to make either one work.
Bdsankey
2,263
89
Neenah, Wisconsin
I did not say swap the fittings.
You know what I meant Mike, the fittings need to be swapped on the 03 trans to the GM adapter fittings if it's a late trans. If the trans is an early 03 then it's a cake walk with zero work required.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
