So I have full control of rail pressure, that is until I start to limit fueling with B0205 (MAF) and B0795 (mixture limit). The more I try and control smoke output in the lower mm3 areas, this weird occurrence happens and gets worse! I plugged in the values that my cp3 flow sheet had, so I'm guessing I need to start tweaking B1015 and see how things respond?
Log attached
Log attached
