  #1
Old 07-12-2016, 10:30 AM
aarolar's Avatar
aarolar aarolar is offline
FNG
Default Just another CP4 failure
So I'm in the middle of rebuilding my fuel system after my CP4 grenaded on me 4th of July weekend and could really use some advice. I have the Fleece CP3K kit on order and think I'm pretty good with that install but the injectors have me kinda nervous. Does anyone have any tips in pulling the injectors on LMLs or any suggestions for tools to make it any easier? Also I am thinking about just cleaning all the injector lines out and reusing then but replacing the rails. Is this advisable or should I replace everything?
Pic of the bottom of my pump laying in the valley.
Sent from my SCH-I545 using Tapatalk
  #2
Old 07-12-2016, 11:57 AM
Slowmax's Avatar
Slowmax Slowmax is offline
Build what others' won't
Default
Attachment 43081
Will need an injector puller, Snap On, or Kent Moore.
__________________
02 Silverado 4 inch turbo back exhaust with muff, A.E.M intake with cone filter, EFi live.
  #3
Old 07-12-2016, 12:21 PM
Tothemax's Avatar
Tothemax Tothemax is offline
xgmtech
Default
I have a used set of fuel rails with 20k on them. Vehicle was totaled. They where on a 2012 Chevy van Duramax. Parts numbers for the rails are the same for a 2012 Silverado. They would come with the sensors still installed. If your interested let me know.
__________________
2017 l5p cc/sb ltz z71 (stormtrooper edition)
06 lbz ec/sb. stock motor, Danville 4094s2r, built trans by me, limitless 1078 converter, 60% sticks, S&S 12mm pump. dyno tuned by mark @ Danville. 775hp 1383ftlb
best so far. 11.440 @ 118.12 1.623 60ft
06 lbz rc/fb dually work truck. Danville tuned
  #4
Old 07-12-2016, 12:34 PM
aarolar's Avatar
FNG
Default
Quote:
Can you give me a link just to make sure we are on the same page
  #5
Old 07-12-2016, 04:20 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
The removal tools are worthless if the injector is stuck... They should pull out by hand with a little twisting action. I have broke the Kent-moore tool on stuck injectors. The best way to remove a stuck one is to get a cheap slide hammer, a impact universal, and a lug nut from a 01-10 8 lug GM (not sure if the thread is the same on the 11+ trucks?) thread the lug nut onto the injector after you remove the High pressure line. I think you can get al of the above tools from Harbor freight for under 20 bucks.
I would clean the rails and lines but that's me... Take them apart completely and use some new gun cleaning brushes, lots of brake clean and some compressed air.
__________________
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #6
Old 07-12-2016, 05:09 PM
aarolar's Avatar
FNG
Default
That was exactly my plan I was going to use a 22 cal bore snake if it would fit.
  #7
Old 07-14-2016, 03:24 PM
aarolar's Avatar
FNG
Default
Pump out this afternoon and the drive gear was busted if anyone has a line on one new or used let me know please.
  #8
Old 07-14-2016, 06:03 PM
Burn Down's Avatar
Default
Wow
__________________
03 Reg Cab ZF 6
  #9
Old 07-14-2016, 06:50 PM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
X2! WTF did you do to it?
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #10
Old 07-14-2016, 08:45 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Damn, thats a bad one. Id be worried if one of the other timing gears is cracked.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD
"Kleshay" -- 2000 C5 Corvette -- the toy
Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom You're already missed, at home and on the piano.
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #11
Old 07-15-2016, 07:08 AM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
My education stopped at CP3's.
Are the CP4's aluminum body? The CP3's are build like tanks, so when I would blow one up, they would just push the guts out the freeze plugs in the CP3 block.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
