  #1
Old 08-31-2013, 12:22 PM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Default Oval Piston Roll Call!!
If you are running a set of ovals, let us know how you are doing. I have not heard from most of you after the sale. That could be could good or bad and I want to know.
__________________
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
  #2
Old 08-31-2013, 12:26 PM
sterlinLBZ's Avatar
sterlinLBZ sterlinLBZ is offline
Default
Mines running good, I get it dyno tuned the 19th and ill let ya know what kind of numbers ill be at! Thanks for your help!
__________________
06 CC/SB 4x4 20" XD spies W/33x12.50 Nitto Extreme terrains. motor build in the process. Carrillo rods, fingers oval cast race pistons (16.0:1), industrial injections stage one cam (209int/216exh.), Hamilton valve springs and retainers, Ats dual fuelers, HTT 66 MM, Suncoast trans/converter/flywheel, fluid damper, stock injectors honed to 45%, 4" downpipe to 4" straight pipe, ARP head and main studs
  #3
Old 08-31-2013, 12:27 PM
DieselmafiaLLY's Avatar
DieselmafiaLLY DieselmafiaLLY is offline
Keep Calm and Go Crazy
Default
you guys should give some info on your build, how many miles on em and the hp levels your running. give us an idea of what they are stading up to and how long!
__________________
Duramax. Little bit of this, little bit of that
  #4
Old 08-31-2013, 12:29 PM
dbev24's Avatar
dbev24 dbev24 is offline
Default
Mine should be running next week
__________________
06 lbz ex/sb
built motor, s475, tuned by ray@ftk
  #5
Old 08-31-2013, 12:50 PM
sterlinLBZ's Avatar
Default
I've got maybe 1,000 miles since I got mine running. I'm hoping for 700+ horse. Everything is in my sig except I went with fingers pistons not the mahle
__________________
  #6
Old 08-31-2013, 01:34 PM
quinton's Avatar
quinton quinton is offline
Default
Waiting on machine shop to finish minr
__________________
EFIlive dsp5 by me, Built trans by me, 68 danville, stock fuel, lifted. died 6/20/2013 Cracked piston. Best time 12.75 on fuel
Alive 11/15/13: lowered, Built motor, s475, plenty of fuel, plenty of spray. Tune 3 fuel only 11.84 @114, Tune 5 little bit of spray 11.45 @ 121. Both times with melted turbine wheel, loose turbo from pedestal with blown out flange gasket. .
  #7
Old 08-31-2013, 02:15 PM
dmax711's Avatar
dmax711 dmax711 is offline
Default
mine will be running soon, I will report back!
__________________
Sold--2005 lly , built motor, triple turbos, dual pumps, 100 overs.
2012 lml Denali , deleted, ppei tunes, fass 150
  #8
Old 08-31-2013, 03:56 PM
Hot COCOAL Hot COCOAL is offline
May the farce be with you
Default
The "OFFICIAL"
I'm jealous of all you bastards
Thread
__________________
Jason-
Founding member of the "knows enough to be dangerous" club...
Hey, I'm NORWEGIAN... you try having a SQUARE head full of ROUND thoughts...
  #9
Old 08-31-2013, 05:50 PM
Evan@LimitlessDiesel's Avatar
Evan@LimitlessDiesel Evan@LimitlessDiesel is online now
yerp
Default
My truck is almost done...again but for the few thousand miles it does have the pistons are good.
__________________
Limitless Diesel Performance
413-770-3585
  #10
Old 08-31-2013, 06:31 PM
rgullett83's Avatar
rgullett83 rgullett83 is offline
Default
I need some more $ to get mine finished. Actually think I may send them back for some valve reliefs before I get started with the rest of the machine work
Sent from my GT-I9300
__________________
Riley
SOLD Mine: 01 CCSB Siverado frame off restored with various parts from 01-06 built lly motor, built 03 trans, 2xcp3, 100% exergys, billet SXE369 and much more that I wont fill this space with...
Hers: 16 High Country CCSB w/minor mods
  #11
Old 08-31-2013, 07:30 PM
prodiesel804's Avatar
prodiesel804 prodiesel804 is offline
Default
motor is done, just waiting on the trany now.
  #12
Old 08-31-2013, 09:05 PM
Vsouth Vsouth is offline
Default
I have a little over 20k miles on my build so far. I have around 80 1/4 mile passes at 840ish hp or so. 8k of that was towing 10k at 650hp. Truck is running great so far. Will be hitting a couple dyno events in the next couple weeks and will see if she wants to go over a 1000hp.
__________________
NHRDA 2011 Super Diesel World Champion
NHRDA 2012 Sportsman World Champion
A big thanks to: Edge Products, Adrenaline Performance, ATPTrucks, Dmax Store, Yukon, Flexalite, Fusion Bumpers, Danville Performance
2006 GMC 2500hd CCSB 4X4: Built to the hilt, and run till she broke!!
  #13
Old 09-01-2013, 05:33 AM
dansdieselp's Avatar
dansdieselp dansdieselp is offline
Diesel Tuner
Default
http://youtu.be/e3mhNHgJtd8
Heather has been either winning or destroying driveline parts this year in her 2.5 truck Hank. John's pistons are working well.
  #14
Old 09-02-2013, 04:21 AM
smarquis's Avatar
smarquis smarquis is offline
Triple Turbo LBZ
Default
subscribed...
__________________
2006 Chevy 2500 HD CCSB EPR Triple Turbos with a Cheetah 68, Turbosock, Air Dog II, Snow Performance MPG Max, EFI Live Tuning by Idaho Rob/Trent Nell, magnaflow converter, 4" Exhaust, EPR Stage Transmission with a SunCoast converter, and trans cooler from SunCoast/Mike L, Brake-man larger brakes up front with Brake man rotors/pads in the rear; 4" Cognito Lift with UCAs, heavy duty tie rods, front anti-sway bar, Pitman/Idler Arm Support Kit and steering braces, Zulastic shackles, Atlas Rear springs, air bags, and 285/65R20 BFG A/Ts on 20x9 BMFs.
  #15
Old 09-02-2013, 05:11 AM
dmax711's Avatar
Default
Come on guys there has to be more feedback then this !
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vB.Sponsors
