Old 10-09-2019, 04:21 PM
Turbo Performance's Avatar
Turbo Performance Turbo Performance is offline
Default New Color Options. Carbon Black and Graphite Gray
Hey everyone,
Have a couple new color options available. Moving forward these will be replacing the original coated black and silver blankets.
Though the originals will be available by request if trying to match a previous setup.
Blanket performance is every bit as good with these colors as they were before.
Shout with questions!
Levi
turboperformanceproducts.com
208)251-9141
Turbo/Manifold/Hotpipe Blankets
Old 10-09-2019, 07:47 PM
Burn Down's Avatar
New colors look good Levi When I get the single cab up and running Ill bring it up to you for some custom blankets on the turbo plumbing.
Albert
04.5’ CCSB ole blue, built trans, mpi twins, 12.5X @ 108
99' Reg Cab, 1500 2wd, Turbo or Procharged 6.0, 4L80E build inprogress
05’ CCSB Millennium Falcon, built eng, built trans, mpi twins, 11.51 @ 119 1.59 60’
84' Reg Cab SB, 415 BBC, 4-speed, needs a D-max zf6 swap
Old 10-10-2019, 05:34 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Are you planning on incorporating the loop-and-pull through method like these blankets show or the same mounting style as previous?
I'm going to end up needing a set once I get my LB7 back on the road (bearing damage so its getting new main/rod bearings, oil pump etc) with compounds. I do need to hit you up about what is going to be the best option for heat protection on the downpipe.
K&D Service Inc
Call or Text: 906-284-0962
Providing a "one-stop-shop" for all of your automotive needs!
Current Rides:
-Built Motor, Triples (2x S369 over a 472), F1 Diesel 300% Inj, Exergy 14mm Street Pump/LBZ CP3, Goerend Bolt Together Converter, Billet Trans, Banks Intercooler, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Built Motor, Big Oil Cooling, Banks iDash 1.8 Monitoring System
Old 10-10-2019, 09:25 AM
Sounds good, give me a shout when you're ready!
I prefer the anchors shown in the picture. In my experience they're a stronger fastener and put less stress on the blanket over time than the grommet style does. With that being said, I can do whatever a customer wants fastener or style wise.
Shout at me when you get closer to being ready and we'll spend a few minutes on what will work best for you.
Levi
208)251-9141
Old 10-10-2019, 06:44 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
I need 2 small turbine T4 blankets for my LS
"OldManTan"
04 SC/SB 1500 Dart 427ci, AFR 6 bolt heads, twin 80mm turbos, TH400 [email protected] 1360rwhp
15 Cruze diesel deleted by Fleece
Tailgate Member #1 I prefer the backdoor
Old 10-11-2019, 08:00 AM
Small? I figured you had went big on literally everything this time around. Build really looks good dude. Send me over some specs on what you need or a measurement and I'll get you hooked up.
Levi
208)251-9141
Old 01-08-2020, 09:46 AM
KyleC4 KyleC4 is offline
are these the colors shown on your website as well? I got a new drop-in style turbo for my lb7 and am looking for something like this instead of factory heat shield.
Concord Chevrolet
Mike L and Inglewood transmission
Old 01-10-2020, 06:09 AM
Yes, most of the blankets are shown and available on the website. Though I'm still working on things here and there. If you need something you don't see, just hit me up. Odds are I can make it.
Levi
208)251-9141
  #9
Old 01-11-2020, 09:33 AM
Thanks. I’ll probably just call you on Monday since I have a few things to run by you for your opinion.
Concord Chevrolet
