  #46
Old 04-08-2019, 12:17 PM
snellgrove10 snellgrove10 is offline
FNG
Originally Posted by slowlml View Post
Unfortunate situation man. You will be happier with the Danville charger. Which one did you go with?
Apologies for the late response! Iím trying to figure out Tapatalk instead of just using the internet website.
Eric at Danville talked me into the bmw 2.5 stage 2 for the valley.
Said it will do everything I want it too.
Atmosphere is a s476/87 1.0ar from bullseye.
-bullseye said this setup will spoil great and be good for 800-850 horse (more than I ever plan)
-Eric at Danville told me I should have went with a bigger turbine and a bigger a.r...
Live and learn I guess!
Hope it runs well
Got me regretting compounds before itís even on there
  #47
Old 04-08-2019, 12:27 PM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Hope it runs well
The turbine/ar choice is way too small for the S476 to work efficiently. Bullseye, if it were my guess, thought you wanted a single as that is a pretty good spot for it is a single.
K&D Service Inc
Call or Text: 906-284-0962
Providing a "one-stop-shop" for all of your automotive needs!
Current Rides:
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, F1 Diesel 300% Inj, Exergy 14mm Street Pump/LBZ CP3, Goerend AR Bolt Together Converter, Billet Trans, Banks Intercooler, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, "Budget" Motor, Big Oil Cooling, Banks iDash 1.8 Monitoring System
  #48
Old 04-08-2019, 12:45 PM
Chevy1925's Avatar
Hope it runs well
if you are staying stock fuel, that setup will be phenominal in the spool up department and for towing.
if you up fueling at all, the 476 may start to fall off in the upper R's
dont feel down on this, your gunna love it
James
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
2002 2500HD CC/LB dmax/6sp alli "The Limo" SOLD - Gone but not forgotten
Tailgate Crew Member #4
  #49
Old 04-08-2019, 12:47 PM
Chevy1925's Avatar
you have not played with enough twin kits on stock fuel/engine trucks
James
  #50
Old 04-08-2019, 12:58 PM
Bdsankey's Avatar
The only one I have experience with was a LBZ with a stroker pump/stock injectors due to his limited funds.
He brought in a kit in a box. It drove decent but fell of really really fast with a 475/87/1.10 as an atmospheric.
K&D Service Inc
Current Rides:
  #51
Old 04-08-2019, 02:44 PM
FNG
Yes! Staying stock fuel for at least two years unless something happens...
Plan on doing trans this winter.
Leaving it that way with (hopefully) a good tune to make it fun and reliable to drive until next winter.
If I do injectors and/or a 10mm pump I would definitely fork up the additional cash to make the changes on the atmosphere side.
-as I stated earlier Eric said anything over 800-850 the atmosphere wonít handle.
-Ron (I think) at bullseye stated this set up will be efficient at 800. So they both seem accurate with each other.
Iíd be happy with 650-700 fun and reliable hp.
-I guess thatís why I should have just stayed single.
We added DMAX store up pipes and manifolds and a ppei oil pan last week while waiting for a valley charger.
Wallet hurts but I hope to be loving life in the next few weeks.
Thanks for the vote of confidence!
  #52
Old 04-08-2019, 02:48 PM
FNG
I called bullseye and talked to Ron over the phone and this is the direction he advised we went with before purchase.
Not looking to break records but hope to have fun and not be back on here talking about a blown bottom end in the next few months
  #53
Old 04-08-2019, 03:15 PM
Chevy1925's Avatar
you will be in the 600, mmmaaaayyyybeeee 650 range max on stock fueling. more than likely 550-600rwhp though.
James
  #54
Old 04-08-2019, 03:23 PM
FNG
That be awesome!
That with a built trans should be a fun truck.
When/if fuel happens 60-100% overs with a 10m pump will happen.
I have been advised to dyno tune with Danville at that time for best results.
  #55
Old 04-08-2019, 04:05 PM
torqued2dmax's Avatar
That be awesome!
Like 1925 said you can have a very efficient , fun and reliable truck , when you go sticks and pump on stock bottom end things can go wrong quickly ! Good luck have fun without braking the bank !
05 CC/LB DRW LLY Allison
  #56
Old 04-08-2019, 05:25 PM
S Phinney's Avatar
S Phinney S Phinney is offline
I would have went with a 1.30 stainless housing on that turbo.
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
