Old 12-08-2019, 11:28 PM
DylOrr's Avatar
DylOrr DylOrr is offline
Gearhead
Default Aftermarket Flexible Engine Dipstick
I was wondering if anybody knows of an alternative for a dipstick tube for these trucks. I built a motor with the 12651877 block and with merchant mounts the dipstick wouldnít go between webbing and the mount. I bent it differently last time but it was right on the starter and I had to wrap it in hose and twist the wire around on the starter to get it to work. The motor is out again because the truck is getting some chassis modifications and I was going to try to fix that while itís out. Just checking to see if anybody knows of anything, or knows If the th400 double o ring style end would work and if I could just get a lokar and make it work. I donít wanna spend $150 on a dipstick and have it not work. Any advice is appreciated. Thanks
Dylan
2004 RCLB- remote mount s480, 200s, dual stock pumps
Old 12-09-2019, 08:13 AM
Chevy1925's Avatar
wish i had an answer for you. i generally just rebend the tube around with a brake line bender.
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
Old 12-09-2019, 12:00 PM
mrhuffer112 mrhuffer112 is offline
FNG
Also interested in this. I bent mine I little too much when I installed twins and now the dipstick catches a little bit when pulling it out.
06 LBZ CCSB, 37x13.5-20, 4.56 gears, truetrac, 8Ē lift, custom trac bars, SDP 75 over 63.5 compounds, SDP trans, fass 95, tuned by duramaxtuner, stock fuel
Old 12-09-2019, 08:15 PM
DylOrr's Avatar
Gearhead
Thatís a pretty good idea Iíve never thought of. Probably be pretty easy to get it right while itís out. I bought a truck that fleece built that had a flexible one in it but unfortunately it got broke taking it apart. I might have to give them a call and see if they have something
Dylan
Old 01-14-2020, 11:28 PM
fl0w3n fl0w3n is offline
Gear star is advertising a flexible tube and stick on their site for some of their transmissions.
I’d give them a call and see if they can help.
2002 LB7/ZF6 CCSB Sierra 4x4
340k miles...SAC45, Super Sport LBZ CP3, Airdog 2 4g 100, Southbend SDDMAXY Organic, Rebuilt ZF6, TCE NP271, Coast Driveline shortened 2 piece
