  #31
Old 11-02-2018, 08:29 PM
FROGMAN524's Avatar
FROGMAN524 FROGMAN524 is offline
OK so turns out the passenger side CV boot was torn and grease it sprayed everywhere so I replaced it with a new GM part today at the shop and then I had them remove the plastic splash guard which was slapping around between the new drop crossmember and the regular crossmember causing a lot of noise. So for the clock is gone but Time will tell. Also I was able to change one of the PID displays on my CTS to to the fuel flow rate and when I went full throttle on the freeway today I was able to verify the change in maximum fuel rate between settings verifying that my switch is working.
2016 Sierra 3500HD Denali CCSB
MotorOps on Spade Tuner/AirDog 165 II-4G/S&B CAI/FloPro 5" SS Turbo Back W/Muffler/30" FTE Resonator/MBRP 6" SS Tip/CTS2 Insight/EDGE EGT Probe/GMC-Kicker Soundgate Sub
Mike L Trans (Goerend R/Alto G3s/RatioTek)
SOLD2015.5 GMC Sierra 3500HD Denali CCSB
SOLD2007.5 GMC Sierra 2500HD SLT CCSB Graystone/Ebony
Z71 4x4 DuraAlli EFILive by ATP Air Dog II 165 G2 Diff Cover Alli Deep Pan TranSynd Cognito Boxed UCAs
Kryptonite Tie Rods Cognito PISK Bilstein 5100s Bilstein Stabilizer PPE Race Valve/Ported fitting MBRP 5" DP Back RBP 6x18" Tip AutoMeter Cobalt Boost & Pyro Advent OGM-1 Nav Method 16x8 Machined BFG KO2 286/75R16 Mike L Suncoast/Goerend
SDP Twins PPE Race Up-Pipes/Manifolds
If wishes were horses, beggars would ride.
  #32
Old 11-02-2018, 08:30 PM
FROGMAN524's Avatar
  #33
Old 11-04-2018, 10:55 AM
FROGMAN524's Avatar
Bad news, clunk not gone. I still believe it is the front shafts having too much play and flopping around in the front diff. Iím going to drop the truck off at the shop this week and tell them they can keep it until itís silent because at this point itís pretty much unbearable to drive and itís driving me nuts.
  #34
Old 11-04-2018, 06:15 PM
catmenace's Avatar
catmenace catmenace is offline
Truck looks crazy good!!! Next thing is to pump up the power.
-2011 GMC 3500 CC LB DRW, Complete SoCal Built Stage II engine with Beehive Titanium retainers, Gapless Rings, Clam Shell Plenum Cylinder Head Mod, Socal Billet Crank, Carillo Rods, Cast 4.075 Oval Bowl .075 Valve Pockets, Thermal Coated, AF Billet Cam, 14 MM Stroker CP3, Energy 150% Injectors, SDP Twins 480/63.5 Stock upgrade, SDP Built Full Billet Trans, PPE Manifolds and up pipes, Dual core transmission cooler with fan, Detroit Truetrac with Timken Bearings, BDS Recoil Traction Bars, Fass 220 lift pump, Beans sump, 5" single piece Aluminium Driveshaft
-2018 Tesla Model 3 Performance 0 to 60 in 3.3 seconds
-2017 Indian Roadmaster Stage 2
Special thanks to:
Scott @ SDP
Blake @ UDT
  #35
Old 11-04-2018, 06:30 PM
FROGMAN524's Avatar
  #36
Old 11-05-2018, 10:25 AM
cdbright's Avatar
cdbright cdbright is offline
JUST RENT IT
curious how the KING rides. I had same setup with FOX and it rode like shit and i lost all my teeth
2016 GMC Denali 2500 4x4 CC/SB LML- 6" Rough Country lift w 20" XDs
2015 GMC Denali 2500 4X4 CC/SB LML - (STOLEN)
2009 Chev 2500 LMM (TRADED) EFI, all deleted, rode just as hard as her !!!, stayed together
2008 GMC 2500 LMM (SOLD)
EFI,all deleted,rode hard,stayed together
  #37
Old 11-05-2018, 08:52 PM
FROGMAN524's Avatar
So far only have about 600 miles on the lift but Iím really liking the Kings provided they are not the source of my clunk. Plus, they look bad ass most importantly.
