  #46
Old 11-02-2019, 07:51 AM
Pure Diesel's Avatar
Pure Diesel Pure Diesel is offline
Randsburg Drifter
Nice runs Rick. Car is looking awesome.
White GMC 2003 2500HD D/A SLE/CC/SB 4x4] Bilstein 5100~Air bags~Autometer Gauges~33 BFG's~MBRP 4" Exhaust~SD tie rod sleeves~Cognito Braces~Kryptonite upper control arms DMAXSTORE XD TIE RODS~PPE high flow pick up~Fass 95 pump~Titan 52-gal.~Prodigy~New tranny 02/12/2015 Mike L. "Baby Frankenstein " w/Goerend converter w/ Mike L. tranny cooler and pump rub fix~6 speed tap shifter~Siege Engineering Anvil train horns(Very Loud)~LED headlights Hi/Lo
New injectors as of 03/12/2010 @ 80k miles
Injectors started going again at 115k. 07/01/2013
06LBZ engine transplant from Russ @ RPM Motorsports~No more Lb7 injectors to replace
'19 Yamaha YXZ 1000RSS
29' 2004 Keystone Laredo 5th wheel
  #47
Old 11-02-2019, 11:57 AM
PureHybrid's Avatar
Isuzu Shakes IT
I thought Rizzi's truck was a lot faster than that
04 GMC ECSB LLY - Mix breed trans/SC1056 - Kennedy twin pumps/pickup - 531/944
8.17@84mph 1/8mi
Jesse
  #48
Old 11-02-2019, 12:06 PM
rfletes79's Avatar
rfletes79 rfletes79 is offline
It is, he was hurt. You can hear the motor knocking after the burnout. He just gave it enough to beat me.
j
1970 Chevelle Duramax Hot Rod, '04 LB7/TH400-gear vendor, HTT 67.7 FMW, Wagler street intake, 65% S&S sticks, exergy 12 mil pump, SoCal AF3388, Valve springs, Push Rods, LBZ rods, cut LB7 slugs..... 9 sec cruzer :-)
2002 2500HD LLY 6 speed ally conversion
  #49
Old 11-02-2019, 01:05 PM
Burn Down's Avatar
Nice runs Rick. Id bet a lot of people would be surprised how stock that engine is for how well that car moves out. Its a real testament for optimizing your setup
Albert
04.5 CCSB ole blue, built trans, mpi twins, 12.5X @ 108
99' Reg Cab, 1500 2wd, turbo 6.0, th400 build inprogress
05 CCSB Millennium Falcon, built eng, built trans, mpi twins, 11.51 @ 119 1.59 60
  #50
Old 11-02-2019, 02:22 PM
prostreeter600's Avatar
prostreeter600 prostreeter600 is offline
Street rodder
I could hear the knocking after the burn out in the video on Tony’s truck . What’s the race weight on your car Rick ? Tony’s truck looks very light .
06 GMC Sierra RCSB Full built motor, carillos, 14/1 Arias W/total seal rings, 9100 AF, SCalTit retainers,SCalsprings,ported heads, SCal pushrods, 625 head studs, O-ringed block, keyed oil pump ,Billet Aluminum Lifters, Harland Sharp Aluminum roller rockers, studded rocker shafts, studded & girdled mains, socal balancer, socal flywheel, PPE Dual Fuelers with twin Fleece 10 mm CP3s , FASS Titanium 260 , 3" bridge, , TRIPLES----2---S369SXEs .88ARs over a Hybrid GTX 4202R--72mm/87mm 1.0 AR ,coilovers at 4 corners, 36" ladder bars, BD cooler, Exergy LBZ 250s ,FF Dynamics fans, PPE mans & ups , MA mounts & TC Brace ,NOS, Full Billet Trans, Suncoast 10531-3D , 3.42 Gears, BT lockup box. 16 x 12s & 16 x 10 Real Wheels with M & H 12/16s and 13/16s. TUNED by MARK@DANVILLE. Engine by Jason Walker San Marcus Tx. Best 60'---1.42 .Best 1/8---6.19@113.24 . Best 1/4 prior to 6.19 is --9.978@136.39
  #51
Old 11-02-2019, 07:12 PM
rfletes79's Avatar
My car weights in at 4540ish with me in it.
It’s taken us some time to get this combo where it is. Literally hundreds of passes (over 400) and data at multiple tracks across the country. I still believe we have more in it. The chassis and trans can put more power down with some more changes. Hopefully we can make those changes this winter and put even better numbers down with this stockish LB7, lol.
We have 1 more race this season in a few weeks, then we’ll see where we’ll end up for this year.
j
  #52
Old 11-07-2019, 09:42 AM
FROGMAN524's Avatar
FROGMAN524 FROGMAN524 is offline
Is the regular Street Outlaws on anymore or just this no prep version?
2016 Sierra 3500HD Denali CCSB SRW
UDP Tunes on V2/SOTF Switch/Danville 63.5 Billet-S480FMW Billet Twins by WCFab(Illusion Blue)/Exergy 100% Injectors/Exergy 12MM CP3/Banks Intercooler/HSP Billet Manifolds/PPE Up Pipes/PPE Oil Pan/PPE Deep Trans Pan/AirDog 165 II-4G/FloPro 5" SS Turbo Back/MBRP 6" SS Tip/CTS2 Insight/EDGE EGT Probe/EDGE 0-100 Boost Sensor/Cognito 4-6/Cognito Front Driveline/Cognito Swaybar/Cognito PISK/PPE Tie Rods/King 2.5 Resis/Air Lift 5000 Ultimate Bags/Air Lift Wireless One Compressor/Wilwood TX6R Brakes Front and Back/LT325/60R20 BFG KO2s/20x9 Method 309s/AMP Steps/Yukon 4.11s/Royalty Core RC1/Retrax Powertrax Pro MX/Titan STAFS 30 Gallon/JL C5s/JL 12TW3-D4/JL VX600/6i/JL XD300/1V2
Mike L Trans (Goerend R/Alto G3s/RatioTek)
SOLD2015.5 GMC Sierra 3500HD Denali CCSB
SOLD2007.5 GMC Sierra 2500HD SLT CCSB SDP Twins/Mike L Trans/ATP Tunes
If wishes were horses, beggars would ride.
  #53
Old 11-07-2019, 10:07 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
They alternate on TV. During the "off season" of list racing they air the no prep kings series and vice-versa.
Current Rides:
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-Tuned by Starlite
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap, LML Oil Pump, LML Piston Cooling Nozzles, 2020 L5P Oil Cooler, Derale Aux Oil Cooler w/Fan, Banks iDash 1.8 Monitoring System
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
