  #856
Old 01-08-2019, 06:58 PM
cdbright's Avatar
cdbright cdbright is offline
JUST RENT IT
i need to see this girl throwing roosters
2016 GMC Denali 2500 4x4 CC/SD LML- 6" Rough Country lift w 20" XDs
2015 GMC Denali 2500 4X4 CC/SB - (STOLEN)
2009 Chev 2500 (TRADED) EFI, all deleted, rode just as hard as her ^^^, stayed together
2008 GMC 2500 (SOLD)
EFI,all deleted,rode hard,stayed together
  #857
Old 01-11-2019, 01:13 AM
kidturbo's Avatar
kidturbo kidturbo is offline
Piston Tester
Just wrapping up the sanding on first piston set. Haven't started the final polishing yet.
Going from a sand blasted surface to somewhat shiny (1500) takes about 45 minutes per piston with a low speed dremel tool. Did I mention I dislike coatings??
Rings arrived yesterday, so need to grind all those gaps down again. Then I'm within about 8hrs of where I was end of November..
Sent from my SAMSUNG-SM-G890A using Tapatalk
  #858
Old 01-11-2019, 08:22 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Well, they look good at least!
  #859
Old 01-11-2019, 08:31 AM
Chevy1925's Avatar
i mean, worse case you can make a really cool table or lamp with them
Just out of curiosity, did you measure bore dia, taper and out-of-round before and after the quick hone? curious if there was any distortion in the little run time and if the ball hone took any out, added any or opened the bore any.
James
best time to date: 12.39
Tailgate Crew Member #4
  #860
Old 01-11-2019, 09:43 AM
kidturbo's Avatar
Piston Tester
We checked for outa round before and didn't notice any measurable difference. Then literally made 3 - 8 strokes with the bead hone just to knock that glaze off in a few spots.
