Old 12-06-2018, 01:41 PM
cjb2283's Avatar
cjb2283 cjb2283 is offline
Gearhead
Default Bulb Upgrade
Has anyone found a LED compatible upgrade for the highs/lows on the LMLs? I have a 2015 and I want them to appear white instead of the nasty yellowish and match the accent lights. I have tried a couple different bulbs and they wont work since they need to be dual filament. Are the 9012 bulbs the same as another bulb by chance? Thank you for any help.
Old 12-06-2018, 02:03 PM
snowman22's Avatar
snowman22 snowman22 is online now
Gearhead
Why not change to an LED? That way you could control the color, 5k being nearly white.
2015.5 LML GMC Denali 3500 SRW 4wd CCLB 90k Miles
Mike L Trans, 4" FlowPro, MBRP Down Pipe, 30" FTE Resonator, S&B Intake, Twin Kennedy Pumps, Bilstein 5100, Edge CTS2
Sold: 2003 LB7 CCLB 350K miles
Old 12-06-2018, 04:49 PM
gmduramax's Avatar
gmduramax gmduramax is online now
Shits broke
Why do they need to be dual? The projector opens up for high beam doesnít it?
10.98@124mph
Tailgate Crew Member #1
Old 12-06-2018, 08:12 PM
ShopSpecialties's Avatar
ShopSpecialties ShopSpecialties is online now
Gearhead
Diode Dynamics 9012 SL1.
2006 Express 1 Ton Ext Dmax van. EFILive, Hella headlamps, Edge Insight CTS, TDK Bumper, TCI deep pan, B&M Super Cooler, Diamond Eye 4" Turbo Back - BYE BYE Kitty and ruffler, Synthetic front to back. Custom air intake with AEM dry filter, Kennedy lift pump, EGR cooler/valve delete.
Chad @ Alligator Performance
Jeremy @ Throttle Down Kustoms
Old 12-07-2018, 08:27 AM
cjb2283's Avatar
Gearhead
I want to change to an LED, I just cant find one that works, yet.
Hmmm...I will have to research this. I have no idea. I will have to watch my lights I guess.
These look promising...expensive! but promising.
Thanks for the replies fellas.
2015.5 GMC Sierra 2500 HD Z71 CCSB LML
-Stock
-Edge CTSII Monitor
-Diamondback HD bed cover
Old 12-07-2018, 10:08 AM
snowman22's Avatar
Gearhead
I have a new saber set from DDM tuning to put in this weekend. Ill let you know how they work out.
Old 12-07-2018, 10:34 AM
Gearhead
Like with most things quality comes with a price. Check out Headlight Revolution on YouTube. They do a lot of testing of bulbs in different oem headlight housings so you can see the difference between a variety of bulbs. I was very surprised at how the big the difference is between beam patterns/brightness of different brands.
https://youtu.be/mZSNrvB_gEE
Old 12-07-2018, 01:20 PM
cjb2283's Avatar
Gearhead
That is impressive! The only thing I have a question about now is whether or not they actually get brighter/dimmer when you flip between brights and dims. Or if the projector opens like gmduramax said.
-Stock
-Edge CTSII Monitor
  #9
Old 12-07-2018, 01:23 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Iím not sure on the factory style projectors but most aftermarkets do mechanically switch to high beams.
2006 LLY CC/SB LT3 mostly stock
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. Fixed and driving again
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #10
Old 12-07-2018, 02:24 PM
gmduramax's Avatar
Shits broke
The ones I didnít see tested were the JDM astar. I get them on amazon for $60. I put them in a 08 Toyota 4 runner and a 2012 Ford Escape. They work well and you can adjust the position of the leds.
Like mentioned I know all aftermarket projectors do open up. Is the factory bulb dual filament?
10.98@124mph
  #11
Old 12-07-2018, 03:48 PM
Gearhead
The 14-15 GMC Sierra projector headlight is a cool setup - it uses a single beam bulb (9012, 1 filament) but creates both your high and low beam patterns separately. The headlight accomplishes this by activating an internal solenoid that moves a cut off shield inside the projector. When the shield is up, you get a low beam pattern with a cut off line. When the shield is down and out of the way you get all the light and a wide flood high beam. This was the description @ Headlight Revolution.
  #12
Old 12-07-2018, 04:53 PM
zakkb787's Avatar
<thatís not me...
Cool. Now we know
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
