Old 12-06-2018, 11:10 AM
PapaBravo's Avatar
PapaBravo PapaBravo is offline
Gearhead
Default New tunes
I have made some changes to my truck and would like to update my EFI Live. I have had the transmission rebuilt, added a lift pump and changed the turbo to a Garrett 4094. I would like to hear any suggestions that you might have.
"Life is hard; it's harder if you're stupid." - John Wayne
240,000miles
PCV reroute, Lift Pump, Garrett 4094 stage 2, EFILive DSP5, Chris
Old 12-06-2018, 01:38 PM
PureHybrid's Avatar
Isuzu Shakes IT
Who's tunes are on it now? Do you own a v2?
8.17@84mph 1/8mi
Jesse
Old 12-06-2018, 02:28 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
What year truck?
Are you looking to make the changes yourself or someone else?
Stock injectors?
What are your HP goals?
Give us a little more to work with and we will be able to help you better
2008 Chevrolet 3500HD DRW LTZ
Old 12-06-2018, 02:51 PM
PapaBravo's Avatar
Gearhead
It's an '06 LBZ, with stock injectors. I'm not looking to making a lot of horsepower. I just want to maximize what I have now. Currently it has tuning from The Neens. I sent him a PM, but I haven't seen him on the forum lately.
240,000miles
Old 12-06-2018, 03:18 PM
superswamper003's Avatar
superswamper003 superswamper003 is offline
You have had the transmission rebuilt as in? Stock rebuild?
Hendrik
2004 LB7-sold
05 lly cc/sb 4wd
pcv reroute, lbz mp, egr block plate, 5" magnaflow, G2 tie rods, ssdieseltuning efi, cts2, SDP built trans, pump rub fix, FPRV shim
270k miles
Old 12-06-2018, 03:39 PM
PapaBravo's Avatar
Gearhead
They put in a billet 3500 torque converter and a trans go jr
240,000miles
Old 12-06-2018, 03:58 PM
TheBac's Avatar
TheBac TheBac is offline
Moved to Tuning section.
Well, if Neens never get back with you, there's always Tony or Mark.
Tom
Old 12-06-2018, 04:45 PM
Burn Down's Avatar
Chris doesn’t get on here but every once in awhile. If you like his tuning I can text him to ck his messages on here.
04.5’ CCSB ole blue, built trans, mpi twins
03’ Reg Cab ZF 6
05’ CCSB ole crappy, built eng, built trans, mpi twins
  #9
Old 12-06-2018, 04:54 PM
PapaBravo's Avatar
Gearhead
"Chris doesn’t get on here but every once in awhile. If you like his tuning I can text him to ck his messages on here."
Thanks! That would be great.
240,000miles
  #10
Old 12-06-2018, 05:43 PM
2004LB7's Avatar
That is definitely not a built transmission. Your new turbo could easily make enough HP to ruin it in a very short amount of time. Keep it under 100 HP over stock if you want any life out of it
Until then, start saving up
  #11
Old 12-06-2018, 08:40 PM
monster50iii's Avatar
monster50iii monster50iii is offline
About all you'll need is an update in max vane tables desired vane tables, and some lowering of desired boost in the lower rpm/mm3 areas being it will be quite a bit more lazy than the stock turbo. May even want to pull some pulse to be safe etc..
Love your country, never trust your gov't
  #12
Old 12-06-2018, 09:45 PM
Burn Down's Avatar
I sent him a text for you.
03’ Reg Cab ZF 6
  #13
Old 12-07-2018, 08:49 AM
PapaBravo's Avatar
Gearhead
Thanks, I appreciate all the information guys.
240,000miles
