  #91
Old 05-16-2015, 07:06 PM
onebaddmaxxx onebaddmaxxx is offline
Default
Quote:
Originally Posted by Evan@LimitlessDiesel View Post
Im looking forward to the testing. I'm building a transmission specifically for it tomorrow and will have everything in next week.
What power range is the truck your installing it in if you don't mind me asking Evan?
__________________
2005 lly-tow rig
2006 lbz- 4l80e, single s476, 200s, 2xcp3 4870lb
  #92
Old 05-16-2015, 07:39 PM
Awenta's Avatar
Awenta Awenta is offline
Default
This is awesome. Excited to see the results. I wonder how much it will hold. And how the rest of the driveline will hold up to the shock.
It definitely takes the load off during staging but that initial hit when you take off I what I'm wondering about.
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #93
Old 05-16-2015, 07:51 PM
Default
I bet thick steel driveshafts will be required. Will probably pretzel a factory alum.
__________________
2005 lly-tow rig
  #94
Old 05-17-2015, 05:10 AM
Evan@LimitlessDiesel's Avatar
Evan@LimitlessDiesel Evan@LimitlessDiesel is offline
yerp
Default
Quote:
Starting in the 600hp range to see what fails then we will be working our way up. I have no issue breaking my own stuff to figure what's going to be needed to make this work. Other then hard parts c3's are not going to be easy make live but with what we already learned from last year we have a head start on making them.
__________________
Limitless Diesel Performance
413-770-3585
  #95
Old 05-17-2015, 06:05 AM
CaptPhil's Avatar
CaptPhil CaptPhil is offline
Default
I will volunteer my truck anytime you are ready for a little more power.
__________________
2005 CC/SB LLY
Big Dipper w/ 1058
Bullseye Double bat S366
12.05 @ 112mph w/ S366, stock sticks, stock CP3
2005 EC/SB LLY The White Devil
Built Motor
Limitless Diesel Comp Trans
Triple Turbo
Dual Fuelers
100% Injectors (Hahaha Sure they are)
10.67 @ 133mph fuel only
  #96
Old 05-17-2015, 06:06 AM
Default
If anyone will figure it out, I'm sure it's you buddy. I assume the ole lbz is taking one for the team then?
__________________
2005 lly-tow rig
  #97
Old 05-17-2015, 08:46 AM
yerp
Default
Quote:
Appreciate the offer Phil but between Mike Graves truck and the shop truck we will have some good high powered test trucks.
__________________
413-770-3585
  #98
Old 05-21-2015, 08:18 AM
JeremyDon88's Avatar
JeremyDon88 JeremyDon88 is offline
Default
Anymore updates yet?
__________________
DD 2016 wt stock for now.
Sold!! DD 2006 Cc 4wd stock for now but FASS lift pump with straight pipe n hyper junk programmer ....
SOLD!!!!!!!Drag truck 2007 rc/sb LBZ stock motor
Everything deleted efi live tuned by PPEI!!!
Calvin's built Trans w/1058 cv and BTlock box. FASS 150 LP race valve... Electric fans and custom hot n cold pipes...
LB7 02
LLY 06
LBZ two 06's
LBZ 07
LMM 08
LML 16
Sold....Work truck 06 Chevy cc/dually stock everything!!!!!
Farm truck 95 Chevy ec/lb 6.5 turbo baby!! Lol
Sold.... 2008 CC Swb 4wd... Deleted with RDL egr delete
Air dog 165,Efi live,4 in flo pro duals with 6in tips.....
Sold 06 CC Swb 4wd Efi live from ATP,egr delete with RDL delete pipe n down pipe,45% injectors,4in exhaust
Air Dog 165, built Trans, fastest pass 60ft 1.8 et 8.4....
Race truck Fastest pass 1/8 mile 7.6 60ft 1.6 @88mph
Only 1/8 mile strips close to where I live!
  #99
Old 05-21-2015, 08:27 AM
TROJAN366's Avatar
TROJAN366 TROJAN366 is offline
Gold Rush
Default
Looking forward to how this works in Mike's truck. Might have to look more into this for the next time I need a refresh.
__________________
05 LLY CC/SB
Roderiques ATV Built Motor, HSP Twins, NLX88/Danville72R,
S&S 200s, S&S 10mm & LBZ, Tuned by Danville Performance
Suncoast Competition trans and Goerend Converter
1125hp/1628lbft 10.52@132
Thanks to
Chris @ Roderiques ATV in Westport MA
Mark Broviak @ Danville
Joe and Dave @ HSPdiesel
  #100
Old 05-21-2015, 06:26 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
I really don't think they will hold up. Our trucks either hook, or break shit in the first 60 feet. Adding a device that puts zero load on everything drivetrain related then 100% load is going to leave parts on the ground.
But ive been wrong before
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.32 @ 150
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel deleted by Fleece
Tailgate Member #1 I prefer the backdoor
  #101
Old 05-21-2015, 06:41 PM
Awenta's Avatar
Default
My thoughts exactly. I don't think you're wrong haha. Everyone's weakest link will be found
__________________
Arek
EFI by Kory
  #102
Old 05-22-2015, 08:00 AM
JoshH's Avatar
JoshH JoshH is offline
Default
I thought a trans brake would be a lot harder on parts than it has been, but I have not had any failures directly caused by the trans brake on the dumpster. I even spray nitrous out of the hole. I know it is only 2wd, but it has pretty sticky tires and has cut very low 1.6 60' times. The u-joints are smaller in the van than what is in the pickups, and the internals in the 4L85 are smaller than the Allison. I think it will hold up better than most people think. I'm sure there will be some learning curve, but I'm excited to see how Sun Coast addresses any weak points they find. I think this will really be a good development for the Allison.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #103
Old 05-22-2015, 08:09 AM
56taskforce's Avatar
56taskforce 56taskforce is offline
Default
Quote:
Not to get off topic but I love the Dumpster Josh and it is getting quit the following
__________________
2006 GMC 3500 CCLB- Danville stage 2 3794,Banks CAC, DHD 3" super high flow intake & 3" hot side pipe, FASS Titanium 150,PPE ported fuel rail & cp-3 inlet fittings, Nicktane/Cat, PPE race manifolds & up pipes, 4"MBRP duel exhaust, 3"PPE down pipe,4.56 gears,Yukon Grizzly locker, Suncoast GMax6 & Goerend R with Mike L springs, PPE deep pan & PTO covers, 1piece aluminum drive line with 1480 u-joints, tuning by Kory Willis and an S-480 waiting introduction to Mark's stg 2.
PLANS:60% over injectors, Sportsman CP-3
Semper-Fi
  #104
Old 05-22-2015, 02:14 PM
JoshH's Avatar
Default
Thanks.
__________________
  #105
Old 05-26-2015, 03:48 PM
IdahoRob's Avatar
IdahoRob IdahoRob is offline
Default
I love launching off a trans brake, best feeling in drag racing, but the suspension/tires need to be set up way differently when using a trans brake compared to foot braking. 2 x 4 trucks shouldn't be a big issue adjusting, but I'd be curious on how the 4 x 4 trucks will react with the available tires/suspension. I feel there will be carnage at first for sure, but this has been the whole diesel game from the beginning. Make power, improve, break stuff, R&D and repeat.
__________________
Please email me with questions at rob@atptrucks.com
2002 GMC 9.36 @ 154MPH SoCal engine, Randy's 48re, Big Twin Diesel
2013 LML, twins, MIKE L @ Inglewood Transmission
2018 L5P, Lift and tires, 14.65 @ 93mph
www.atptrucks.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
