Old 04-27-2018, 07:52 PM
Bbuchanan11's Avatar
Bbuchanan11 Bbuchanan11 is offline
Gearhead
Default noise with door open or hood open
Iíve tried to google this but what is the rod on the turbo that moves when you open and close the doors or open the hood? And why does it do that?
06 Silverado lbz 11.77 @115 sold
17 Silverado L5P ltz custom sport stock
06 gmc arp studs and mains Callieís crank corrillos mahle Pistons wagler alt fire street cam.big dipper trans precision converter. dual fuelers 60 overs 75 over 66, 5600lbs... track times coming soon
Old 04-28-2018, 03:11 AM
02greysixer's Avatar
02greysixer 02greysixer is offline
Sounds like vgt actuator. Previous generations of Duramax used engine oil pressure to control the vgt. On these engines the sweep or self test could only happen with the engine running. The l5p uses an electric actuator to control vgt. I'm not sure why it sweeps every time you open the door or hood but the reason for the sweep or self check is to keep the vgt freed up and working.
Sent from my SM-G930P using Tapatalk
2010 LMM CCSB LT
4" Flo-Pro
FASS 150
Beans Sump
Leveled w/ drop shackles
RidgeRunner Tunes
More to come
Rip zf6 swapped lly
Old 04-28-2018, 11:14 AM
Gearhead
Yeah it’s weird you can hear it when I open the door then like 30 seconds after I close it you can hear it again...
