Old 11-29-2019, 11:48 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default Craigslist lathe
I've been looking for a lathe for my garage for a while and seen two one Craigslist that seem to fit the size I'm looking for
I'm not looking at anything super precise or fancy, just something to make a few one off parts or fix things and learn more about lathe work
Here are the two I'm looking at. Emailed both and they say they are still available. The one in Napa area is a little closer and I don't have to fight any Bay area traffic. It is a Southbend which means it should be a bit easier to find support and parts for it. The one in the San Francisco area is probably a number of years older. Doesn't have as standard backing plates, tapers to live ends, etc. But what it does have going for it is several chucks, a decent amount of tooling, and quite a bit of other odds and ends that come with it
https://sfbay.craigslist.org/nby/tls...024544019.html
https://sfbay.craigslist.org/sfc/tls...026045963.html
Which one would you guys get out of these two? Should I get the tried and true southbend or go with the fully equipped star lathe?
I know tooling can add up quickly so the star one is looking pretty good but if it has issues fixing it can be a pain.
If I pick up any I'll need to head out today. Otherwise I'll likely have to wait a week and they may be gone by then
2008 Chevrolet 3500HD DRW LTZ
Old 11-29-2019, 02:05 PM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
Personally I wouldn’t buy either one of those. I would look for a gear driven one, all them belts suck...
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
Old 11-29-2019, 02:11 PM
duramaxzak's Avatar
Wanna be puller!
This is what I have and works good. Came with 2 3 jaw chucks, 4 jaw chuck, quick change tool post and some tooling for $3k.
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
Old 11-29-2019, 03:14 PM
2004LB7's Avatar
3k is way above my budget. I'm hopping for about $500 or so. It won't likely see too much use. More for hobbies and learning.
There doesn't seem to be a whole lot of good options around me that are affordable so I will likely end up with an older belt driven one. If it ends up that bad maybe I'll convert it down the road and add a VFD or something
Old 11-29-2019, 07:26 PM
Chevy1925's Avatar
You gotta look for estate sales or auctions and so on. I found mine through a friend as he was closing their machine shops doors.
I wouldn’t buy either either. In fact, I’d buy a 13” lathe knowing what I know now. I have a 10” and it is great for small to shmedium stuff but I hate the fact I can’t turn drums or rotors on it as most of the brakes at my house are too big for it.
I know those old style also use babbet bearings too which wear out and are not the easiest to replace.
Keep lookin
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
Old 11-29-2019, 08:47 PM
2004LB7's Avatar
If I could fit a larger one in my garage I'd be tickled pink. There has even been a few times I could have turned some rotors too if I had one
The babbet bearings do concern me a little but anything better seems to command a premium around here. My brother has been scoping out estate sales and so far its only been junk or its gone the first hour and he never gets to see it.
I could probably rebuild the babbet bearings if I have to but roller bearings would be ideal for sure.
Any good ones that are priced right seem to be too far away. Even these two are further than I would like to travel but I'm not seeing much closer.
Since I lost any chance today to look at them I'll keep looking. If they are still available next week then maybe I'll take a drive out and see them in person
Old 11-30-2019, 10:34 AM
04chase 04chase is offline
If turning rotors is the only reason you want a bigger lathe. The amount a decent lathe will cost . Even used decent will be 1k for a good american vintage lathe.
I personally have a mini lathe I use for mobile work and its only a 3x12 similar to harbor freight but with good tooling and quick change posts.
What type of parts are you making? Size is everything , fit as big as you can and be patient on deals. The best I've found are indeed at estate sales and even they will go for some decent amounts. The Taiwanese stuff seems to be better than most china stuff but still nothing as good as low use old vintage made machines. Be patient and do your homework.
Sent from my SM-G950U using Tapatalk
-2018 Audi S4
-2007 LBZ CCSB LT3- 3794 stg 2 ,efi dsp5, custom coil over ,deaver 1/2 ton 4" springs , Mike L Trans , fass 150 , k3la ,bolt ons 600whp/1100wtq
-1955 Belaire
-2012 Ram 5500 6.7 -Kelderman 4 link rear/front , accuair elevel ,service truck #CHASETRUCKMOBILE
dreams sold
09 CTS-V 800 WHP Daily
04 SS Silverado TT 440 LSX 1200 AWHP-Truckin throwdown winner 2012
Old 11-30-2019, 11:33 AM
2004LB7's Avatar
I probably won't cut anything over 6" diameter. Rotors would be nice but they are not too expensive and it would take a lot of rotors to equal the cost of a larger lathe
I'll probably just be turning down plumbing fittings, bolts, electrical motor shafts, etc. Not too big or long
  #9
Old 12-01-2019, 09:29 AM
gmc502 gmc502 is offline
I scored a nice little WT tool lathe,,came w/ a couple of chucks and a whole lot of tooling for $450.
tried to buy this super cool drill sharpener from him but no dice.still have his number.may try again.
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
  #10
Old 12-01-2019, 09:48 AM
2004LB7's Avatar
I sharpen my drill bits on the bench grinder. While I can't do split points like the drill doctor they work just fine
  #11
Old 12-27-2019, 05:56 PM
here you go
https://boston.craigslist.org/gbs/tl...045485816.html
  #12
Old 12-27-2019, 06:20 PM
2004LB7's Avatar
As cool as that lathe is, its like 3000 miles away. Good find though for someone closer
  #13
Old 01-14-2020, 09:39 AM
2004LB7's Avatar
How about this one?
https://sfbay.craigslist.org/eby/tls...055686957.html
  #14
Old 01-14-2020, 09:43 AM
Chevy1925's Avatar
dont look bad to me! id pick it up for what you are after. you can always tweak it into running true if its a bit off
James
