  #16
Old 01-14-2020, 07:55 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Originally Posted by WolfLLY View Post
I did too. The problem is diesel exhaust is too slow. I had much better results just venting to atmosphere. We all know the physics behind the design, but sometimes the practicality of them come into question. I too just vent to the atmosphere now. Simpler and works every time. Jmo
Good to note. I need to do something as just running a hose to the ground is going to get me flagged at the local track as they believe it is a safety concern.
Current Rides:
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-Tuned by Starlite
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap, LML Oil Pump, LML Piston Cooling Nozzles, 2020 L5P Oil Cooler, Derale Aux Oil Cooler w/Fan, Banks iDash 1.8 Monitoring System
  #17
Old 01-14-2020, 08:49 AM
DuramaxRamRod's Avatar
DuramaxRamRod DuramaxRamRod is offline
Gearhead
Originally Posted by Chevy1925 View Post
not unless you want to pressurize the crank case. Up pipes are under positive pressure the moment you start to come on boost (actually before boost comes on but close enough).
But what about the flow through the up-pipe? Its not deadheaded so it shouldn't push into the crankcase.
'19 Silverado 3500HD CCLB L5P 4x4
Banks Derringer
'03 Silverado 2500HD ECSB LB7 4x4
EFI Live by Idaho Rob
  #18
Old 01-14-2020, 08:52 AM
Bdsankey's Avatar
Gearhead
It's physics at the end of the day, air/fluids (air can be analyzed as a fluid) will always flow from high pressure to low pressure via the path of least resistance. The crankcase is under MUCH less pressure than the up-pipes are thus the exhaust flow will try and go into the crankcase via the lines ran to the up-pipes.
Current Rides:
-Tuned by Starlite
  #19
Old 01-14-2020, 09:14 AM
Gearhead
But this is an evac/eductor type fitting. Besides pressure there is also velocity, which also plays a role in fluid flow. Otherwise eductors would not exist.
Banks Derringer
  #20
Old 01-14-2020, 09:15 AM
Bdsankey's Avatar
Gearhead
I've never seen a fitting like this in a high pressure scavenge situation in an industrial setting. The other thing you will be doing is impeding flow in the up-pipe to a large degree.
Current Rides:
-Tuned by Starlite
  #21
Old 01-14-2020, 09:37 AM
Gearhead
The up-pipe is not a purpose built eductor so I don't know how well this fitting actually works at creating a similar effect.
Banks Derringer
