Old 03-21-2014, 05:57 PM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Default The Highest Form of Flattery
From a friend.
Not my pistons.
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
Old 03-21-2014, 05:59 PM
Dirtymaxx03's Avatar
Dirtymaxx03 Dirtymaxx03 is offline
Greg hogue or wade moody. I've seen a pic of that wide bowl piston before.
Sean
2003 Lb7
Efi Live
The Rabbit-build in progress
1984 2wd SB c10
Originally Posted by hondarider552 View Post
big balls if you measure in seconds of duration
Old 03-21-2014, 07:17 PM
S Phinney's Avatar
S Phinney S Phinney is offline
It isn't Wade for sure. Probably not Greg either.
Sent from my XT1080 using Tapatalk
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
Old 03-21-2014, 06:57 PM
smkndmax05's Avatar
smkndmax05 smkndmax05 is offline
"Smoked Out"
Yours is on the right, or are you saying arias copied you?
Built Motor- 15/1 Diamond Forged Racing, FPE Triples Billet 368s and 480, FPE Heads,2 10mm FPE CP3 pumps, 225% S&S Injectors, MA mounts, Socal 3388 & dampener, HSP Billet Manifolds and upipes, FASS 260/Billet Pick-up, ARP's everywhere, Yukon Gears/Grizzly Locker, ISSPRO Gauges, Banks Intercooler, 2/4 lowering kit
325/45/18 HOOSIER Radials on 18x10s Racelines
9.65@140
FPE DSP5 and manual VB duraflight
Towrig/DD 2011 LML tuned with a FPE 63/71 VGT and a CP3 conversion
Old 03-21-2014, 07:07 PM
Muff's Avatar
Muff Muff is offline
Just Learning
Im guessing hes saying they copied them? Is your design patented?
The Learning Curve
2007 Long body - EFI - Built Transy < She was my first. SOLD
"Vern" 2002 Reg can (with a cap) 300,000 original miles. Lowered, tuned, sold to some jackass who blew it up instantly.
"Vendetta" Nobody knows but she gonna eat
You cant put a price on fun
CaptPhil's Avatar
CaptPhil CaptPhil is offline
are those Arias pistons on the right also? Good copy job if so, too bad you didn't patent the bowl design.
2005 CC/SB LLY
Big Dipper w/ 1058
Bullseye Double bat S366
12.05 @ 112mph w/ S366, stock sticks, stock CP3
2005 EC/SB LLY The White Devil
Built Motor
Limitless Diesel Comp Trans
Triple Turbo
Dual Fuelers
100% Injectors (Hahaha Sure they are)
10.67 @ 133mph fuel only
Old 03-21-2014, 07:40 PM
Fingers's Avatar
Village Idiot
It is a poor copy. Missed some very important details.
My design is not patented. What they have done in the picture would have been hard to call infringement anyway.
'04.5 EC/LB 4x4.
100 over injectors.
PPE Dual CP3s
100 PSIA MAP Sensor
Old 03-21-2014, 07:44 PM
Muff's Avatar
Just Learning
Why are yours not patented?
The Learning Curve
  #9
Old 03-21-2014, 07:57 PM
Fingers's Avatar
Village Idiot
Why would I?
The cost of filing is fairly small, but to do it right, you need a patent attorney.
Super small market. In 3 years, I've only made enough money to make payments on the machine that makes them.
The "copy" in the picture would not stand as a patent infringement. But taking them to court would cost me plenty. And for what?
Lastly, I've been down this road before. In this case, the oval cut in the top of a piston is NOT new. The application appears to be, but I am not willing to cough up the math that makes it work to justify the application to the patent office.
In short, I'm flattered. Now if they would just get it right.
'04.5 EC/LB 4x4.
100 over injectors.
PPE Dual CP3s
100 PSIA MAP Sensor
  #10
Old 03-21-2014, 08:06 PM
DIESELMAFIAPER.LB7's Avatar
DIESELMAFIAPER.LB7 DIESELMAFIAPER.LB7 is offline
<----twinz
so the one on the left is theirs? yours on the right? or both are theres? Im a little lost
2003 GMC CC/SB: billet 66/83mm compounds, dual pumps, exergy injectors, built trans (by me) tuned by me 11.11 @ 124.63mph @ 7100lbs
2012 mega cab 6.7: Tuned and deleted (reliable) sold! (should have kept it)
2016 CCSB custom sport lml ltz deleted with sotf tunes by me
  #11
Old 03-21-2014, 09:08 PM
CaptPhil's Avatar
both are Arias pistons.
2005 CC/SB LLY
Big Dipper w/ 1058
Built Motor
Triple Turbo
Dual Fuelers
  #12
Old 03-21-2014, 08:48 PM
zf>allison's Avatar
zf>allison zf>allison is offline
you never had your car.
When I get mine they will be from you
04.5 single cab lly zf6 barely not stock.(the jalopy)
05 single cab lly zf6
Arp studs, welded water pump, 100 overs, dual fuelers, valair 1000 hp triple disc, danville efi live, fass 150, custom single s400 kit,
serious weight reduction
28x10x16 Hoosier slicks on pyos
Down on 2 leaves, t bolts gone.
best
10.91 at 129mph, 1.577 60 foot
dynoed 743 hp raceweight 5k with driver
Instagram-636zf6
  #13
Old 03-24-2014, 06:59 AM
MACKIN's Avatar
MACKIN MACKIN is offline
Smell My Finger...
Happens to everyone in this game. Well it has been for years that I recall. As he stated the small market and costs to protect your product exceeds the return. I'm surprised it took this long the only thing that sucks is it's a well know company with a well known name in pistons. Hopefully they wont have failures do to not being "right" as reported ,then it could become a bad tarnish for Fingers that would suck!
I have nothing want nothing because what I have cost me to much to have.
01 Big Dually (Gone but not forgotten)
05 Fat-Boy (gets it done)
83 CJ7 (slug but cool)
07 Audi A4 ( I like German Girls they're HOT!!)
LIFES JOURNEY IS NOT TO ARRIVE IN HEAVEN SAFELY IN A WELL PRESERVED BODY,
BUT RATHER TO SKID IN SIDEWAYS,
TOTALLY WORN OUT, SHOUTING,HOLY SHIT WHAT A RIDE!
  #14
Old 05-30-2014, 08:13 AM
btfarm's Avatar
btfarm btfarm is offline
you know
Dingaling-aling! Winner!
That very thing cost our company untold millions in lost machine sales and credibility issues over several years because of a poor copy that failed miserably.
Mike
2006 GMC EC/SB SLT. LBZ on Predator.
Blocked, Fingered & PCV Reroute. DE 4" SS DP Back
BFG 285s on PYOs. Putnam CL V, Prodigy. Adrian Box. 285,000/6545 hrs as of 5/15/15
Proud US Navy Veteran & NRA member
  #15
Old 05-29-2014, 09:03 PM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
LMAO, what a joke! It's a poor wannabe copy at best. Some people will do anything to try and get a piece of someone else's business. I will only use the Finger's pistons, period!
06 LBZ "White Lightning" 2wd rclb Stockish Grizzly Locker 3.42 gears Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out TCTLMMStg2 Exergy 12mmcp3 1/8th 7.93@88mph 1/4-12.408@109.18mph
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
Proud and Honored to be able to say I'm the tuner for some of the Quickest and Fastest Dmax's out there! Stock motor Dmax pass with bolt ons and vgt(JKlennon - 9.802@ 139.53 (5/2/19) Fastest Allison equipped Dmax power truck and first into the 5's with an Allison(Mike Graves Prostreet - 9.068 @ 161.19 (7/16/17)Fastest Crewcab with an Allison(Mike Graves 9.555@149.50(4-22-17) Fastest LLy and Fastest street Truck ever(bcdeutch731 C-10 - 8.395 @ 168.13 (9/22/16) Fastest LMM ever(Harbin_22 - 10.12 @ 138.12 (05/01/18) The #1 and #2 Fastest ZF6 trucks in the world (Ryan Pini LLY ZF6 10.674@132.4mph) #2 is with a stock engine(Jesse Rhodes 10.912@130.27mph)
