  #46
Old 12-04-2015, 08:22 AM
Potthoffdmax's Avatar
Potthoffdmax Potthoffdmax is online now
Default
Sub. Glad to see you still working at this.
__________________
EFI live, ARP Studs, shim kit, Afe stage 2 intake, Air Dog 150, Exhaust 4inch, MikeL trans , Autometer gauges, DHD Centerlink Brace, Dmaxstore Tie Rods, pump rub fix.
2017 wrx six speed..
  #47
Old 12-04-2015, 09:00 AM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Default
Actually, The Accel/Decel is there, but they are much harder to see at higher RPM. Data points on those plots are at 6 which is good for velocity measurements. 60-150 counts per data point depending on sampling rate.
Changing the data to velocity and scaling the plot as a percentage of max velocity gives these which show your expected variation. The top plot is the raw counts per tooth data and the bottom the velocity as a percentage of Max
Even so, there seems to be another frequency at work over the 4/rev. More so in some of the plots. This is even when accounting for the published dither in the DAQ's sampling rate.
These are all from old data that was not intended to look for velocity or torsional changes. They also only look at 2 revolutions of the crank which does not give me enough data to do a proper Fourier transform and find other harmonics.
I suspect the crank is resonating torsionally. Thus the new tone wheel for the front. The tooth count could have been a lot less, but I decided to start with the same count as the flywheel.
To see the flex when running up to about 4000 RPM, I will need to sample at
240KHz to get 1/10 increments. However, I expect to see much more flex at the lower RPMs. I think that is where the problem is.
__________________
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
  #48
Old 12-07-2015, 10:23 PM
Fingers's Avatar
Village Idiot
Default
Slow progress....
__________________
'04.5 EC/LB 4x4.
100 over injectors.
PPE Dual CP3s
100 PSIA MAP Sensor
  #49
Old 12-07-2015, 10:42 PM
Dallas S Dallas S is offline
Default
Looks like a cummins! Nice work!
__________________
2006 SLT cc/sb LBZ/Allison/np273c D60 SAS 40x15.5r22
2006 LT RC/SB LBZ 4x4
1980 k1500 lq4/4l80/np205 39.5's on a d44
  #50
Old 12-07-2015, 11:31 PM
RPM Motorsports's Avatar
RPM Motorsports RPM Motorsports is offline
smokinum
Default
Got another broke crank in the shop if you want me to send it your way. Behind #1 main, I can cut the other side off for less shipping weight if you want to inspect it. GM replacement motor 20k mi.
PS: need to get a set of std or .020 Pistons headed this way asap, I'll Ring you tomorrow.
__________________
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
  #51
Old 12-08-2015, 07:24 AM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Default
Oh, Jason is getting some love!! Hate he broke his crank but glad he's finally getting his built engine!
__________________
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
  #52
Old 12-08-2015, 09:37 AM
fastpunker's Avatar
fastpunker fastpunker is offline
adrenaline junkie
Default
subd.
Nice write up and great to see someone digging this far into it Fingers!
Can you post some Pictures of the broken crank... preferably close ups of the broken edges? I am curious to see what the fracture properties look like... crack propagation, deformation, etc. I am in no way trying to step on anyone's toes by asking, just curious for myself given my current job and schooling.
__________________
Jon
Chrysler Powertrain Engineer by day and still happily driving my Duramax by night
2003 CCSB SLT 4x4 250K
best time to date: 12.769 @ 105.34
Stock motor/sticks/studs/turbo
Built trans (Gmax5R/MLG), traction bars built by me, lift pump, 3.5" turbo horn built by me, boost valve (replaced with 1/4" regulator), etc.
Built prerunner 2001 Tacoma extcab: Total Chaos LT, Kings all the way around, Deavers, bed cage, etc.
Big thanks to James, Steve, Brian, Levi, Josh and others for the knowledge and help along the way
  #53
Old 12-08-2015, 10:16 AM
smokinum
Default
Will do!
__________________
(Russ)
  #54
Old 12-08-2015, 11:04 AM
fastpunker's Avatar
adrenaline junkie
Default
Will do!
Thanks
__________________
Jon
  #55
Old 12-08-2015, 11:57 AM
Fingers's Avatar
Village Idiot
Default
I don't need another one laying around the shop. Thanks for the offer.
There are a number of pictures on this site of broken cranks. Most of them are excellent.
__________________
'04.5 EC/LB 4x4.
100 over injectors.
PPE Dual CP3s
100 PSIA MAP Sensor
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
