Old 10-19-2018, 05:10 AM
DMAX Slim's Avatar
DMAX Slim DMAX Slim is offline
Collywobbler
Default 4.3 V6 Turbo????
Anybody done a turbo on a 4.3 V6? I have a 1993 Sonoma I drive to work and run errands with etc. and been thinking about this to wake it up a little, how hard would it be to put a turbo on it?
2003 CC/SB LB7 "The Ole Heifer"
1056-Suncoast internals
Built by SMR Diesel Performance
1993 GMC Sonoma 4WD V6 D.D.
Jesus Is The Only Way!
2002 RC/LB LB7~~Sold~~
Old 10-19-2018, 05:24 AM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Wonder how compatible a setup off of a GN or Syclone/Typhoon would be? They're both turbo'd 4.3 V6 from the factory.
I wonder what those factory boosted applications did for the head gaskets? Isn't head gasket failure fairly common on 4.3? Adding boost sure wouldn't help that I wouldn't think.
Where's Johnboy when you need him?!?! He's probably forgotten more about turbo'ing the 4.3 than most of us will ever know - he played with the GN before he got into the duramax IIRC.
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
Old 10-19-2018, 05:37 AM
NC-smokinlmm's Avatar
<<<Future tuna killer
Trans won't take anything over stock...
I learned a whole lot when I was researching for my SCSB build.
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900 @ 10#'s, BTR titanium valve train, BTR custom grind boost cam, head work, 10% overdriven balancer, 2.8 griptec, 65lb sticks, Mayhem built and tuned, not enough traction yet
1969 MGB GT MKII Factory Condition
Old 10-19-2018, 09:44 AM
gmduramax's Avatar
Shits broke
The syclone my dad has bent the rods at 22psi and never had head gasket issue. I do think it bent the rod from detonation though. Not sure what trans was in it but it was stock and ran 12.9
10.98@124mph
Tailgate Crew Member #1
Old 10-19-2018, 11:32 AM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
I did the 4.3 delete mod and put in a Dart 416ci instead lol
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.32 @ 150
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel deleted by Fleece
Tailgate Member #1 I prefer the backdoor
Old 10-19-2018, 11:55 AM
PureHybrid's Avatar
Isuzu Shakes IT
The Buick wasn't a 4.3, but they may have some similarities. I always thought intake gaskets were the real problem, but I wouldn't be afraid to boost one.
8.17@84mph 1/8mi
Jesse
Old 10-19-2018, 12:47 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
I had a vortech supercharger on a 1992 4.3l S10. The biggest problem is the that is a CPI motor and I would think you'd run out of fuel. The one I did I switched to a carb. It was a stock shortblock and made 10psi, ran good but never had it on a Dyno. The stock 4.3 head flow like crap and the stock cams arnt much. The intake gasket issues we're on the later 4.3s where they switched to a plastic gasket. Felpro makes and replacement. GN is a 3.8l motor
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, sdp y bridge, big dipper trans, 60 overs, 10mm pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
Old 10-20-2018, 03:02 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
The cpi would be your limiting factor. That single injector simply can't flow enough fuel. You could always pick up a 4.3l marine intake(looks like the 4.3l vortec, but is made of cast iron with external injectors), do an 0411 ecm swap easily enough, swap in a 4l60e from a 5.7l and build it, and then add some boost.
  #9
Old 10-20-2018, 06:59 PM
DMAX Slim's Avatar
Collywobbler
Thanks for all the suggestions and letdowns, lol. I now realize itís just a daily driver and will probably stay the way it is until something major happens to it. I hope thatís a while, itís a 1993 with 146k miles on it.
  #10
Old 10-20-2018, 07:33 PM
Originally Posted by DMAX Slim View Post
Thanks for all the suggestions and letdowns, lol. I now realize it’s just a daily driver and will probably stay the way it is until something major happens to it. I hope that’s a while, it’s a 1993 with 146k miles on it.
Put a racetronix fuel pump in it a buy a NX wet kit A 100 shot would be plenty fun
  #11
Old 10-20-2018, 08:32 PM
gmduramax's Avatar
Shits broke
Now weíre talking
10.98@124mph
