Old 09-27-2019, 12:55 AM
02ilduramax's Avatar
02ilduramax 02ilduramax is offline
Default bored at work
Ive thought about the different intake manifolds that are out there for the duramaxs because just about anything has to be better than the stock design in a performance application, but my question is if you wanted to make an intake out of alum how thick of material would you need to hold the boost that some of these trucks make??
build it til it breaks
2002 lb7 cc/sb afe stage 2 intake, MBRP 5in exhaust, airdog-165, efi live tuned by dans diesel performance, tie rod sleeves, stage 4 trans by mike l
Old 09-27-2019, 12:34 PM
Tothemax's Avatar
Tothemax Tothemax is online now
xgmtech
i would think you could make it as thin as the boost tubes? probably would want the sealing surface that bolts to the heads around 3/16. just my thoughts never built one.
2017 l5p cc/sb ltz z71 (stormtrooper edition)
06 lbz ec/sb. stock motor, Danville 4094s2r, built trans by me, limitless 1078 converter, 60% sticks, S&S 12mm pump. dyno tuned by mark @ Danville. 775hp 1383ftlb
best so far. 11.440 @ 118.12 1.623 60ft
06 lbz rc/fb dually work truck. Danville tuned
Old 09-27-2019, 12:57 PM
gmduramax's Avatar
Shits broke
If it was round I would agree. If there’s corners it’ll need to be thicker. Honestly I don’t think the intake is restrictive. Now the exhaust side needs a lot of work
10.98@124mph
Tailgate Crew Member #1
Old 09-27-2019, 01:41 PM
Originally Posted by gmduramax View Post
If it was round I would agree. If thereís corners itíll need to be thicker. Honestly I donít think the intake is restrictive. Now the exhaust side needs a lot of work
I feel like in a full race or puling truck though there would be better options
Old 09-27-2019, 01:55 PM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
We have better options, like the Wagler intake setup. SoCal also mills the intake clamshell area if you choose that service. The factory clamshells aren't a limitation IMO.
Current Rides:
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Tuned by Starlite
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
Old 09-27-2019, 02:08 PM
gmduramax's Avatar
Shits broke
Maybe if youíre running aftermarket heads
10.98@124mph
Old 09-27-2019, 02:50 PM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Why don't gas outfits settle for well-ported clam shell intakes then? Are they pushing that much more CFM through their air pumps (engines) compared to us/diesels that they reap the benefits of those intakes like the Holley EFI one for the LS engines or that rad one from NRE for their big power builds? Why don't we see more intakes for the V8 diesels that resemble those style of gasser intakes?
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
Old 09-27-2019, 02:59 PM
kind of my thought I know in serious race engines they mess with runner length/volume/velocity
not knocking anything that is out there but thinking out loud I like to fabricate and have some background in race engines and have thought about building something for my s10 repower
  #9
Old 09-27-2019, 03:19 PM
TheBac's Avatar
TheBac TheBac is offline
Boosted application is different than naturally aspirated.
Tom
  #10
Old 09-27-2019, 03:28 PM
Bdsankey's Avatar
Gearhead
I donít think itís as important on a boosted application, especially those like race Diesel engines pushing over 100psi of boost. Could we benefit from a runner style but I donít think the gains are massive.
Current Rides:
-Tuned by Starlite
  #11
Old 09-27-2019, 03:35 PM
gmduramax's Avatar
Shits broke
Because they donít fit with a turbo and cp3 in the valley. Banks has a decent option. When youíre making 1500hp I would consider changing the intake if you had the room and enjoy your 15hp gain. Mark went from stock heads to wagler heads IIRC and picked up something like 80hp at the tires. The clamshells are not a limitation unless you spend 8k on heads
10.98@124mph
