Old 05-26-2018, 07:11 PM
Philv's Avatar
Philv Philv is offline
Default Loping idle
So I've been doing a lot of research and I'm still not certain on what's causing my issues. Some say I need injectors, but then someone else has roughly the same problem as me and it's the fpr. I tried to upload 2 videos, but it says files are too big. Could someone pm me their number or email, and I can send them to try and figure out where I should start?
Also forgot to mention, longer crank times at temp and truck falls on it's face on wot. Half throttle it'll move pretty good. And I still can't do a burnout.lol
Sent from my Moto Z (2) using Tapatalk
2001 GMC Sierra 2500HD SLE EC/LB 4x4
LDS 45% SAC injectors
Airdog 4G 165 lift pump
Cold air intake
4" straight exhaust 6" tip
PPE boost valve
Glowshift gauges
Old 05-26-2018, 08:08 PM
Burn Down's Avatar
Burn Down Burn Down is online now
Lots of info on here about t/s and diagnosing lb7 injectors and fpr... I would start with the basics.
04.5’ CCSB ole blue, built trans, mpi twins
03’ Reg Cab ZF 6
05’ CCSB ole crappy, built eng, built trans, mpi twins
Old 05-27-2018, 05:29 AM
WVRigrat05's Avatar
Wound for sound
Prolly injectors, do some tests and you’ll figure it out, or drive it til it blows up, that’s what I usually do.
Reger
100k miles. Piston eater.
Old 05-27-2018, 05:31 AM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Sounds like injectors are returning to much fuel.
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, sdp y bridge, big dipper trans, 60 overs, 10mm pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
Old 05-27-2018, 07:15 AM
04Max's Avatar
04Max 04Max is offline
FNG
Same problem I had when the injectors started going bad. Seemed like it had a race cam lop at idle. Off idle run smooth. Sounded bad at red light stop. Did that for about 2-3 mo. then started the gray smoke. Tried all kinds of injector cleaners along the way. Some helped but the only thing that fixed it was new injectors.
04 Chevy LT 2500HD EC/ShortBed LB7/Allison 2WD
ATP AutoCal - Isspro Boost & Pyro Gauges - Kennedy Lift Pump - Racor Diesel Filter Kit - Cat Filter adaptor - PPE Boost valve - AFE CAI - Profab air horn - MotoBlue Quite Thunder Down Pipe - FLO-PRO 4" SS exhaust - Allison Deep Pan - Velvet-Ride Springs - Air Lift springs & compressor - Line-X Liner - Hard Folding Tonneau Cover
Old 05-27-2018, 04:53 PM
Philv's Avatar
The reason why I don't think injectors is 18.5 mpg doing 75-80. I guess I just need to replace everything on the fuel system.
Cold air intake
PPE boost valve
Glowshift gauges
Old 05-27-2018, 05:26 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
Do LLY top end swap...
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900, lots of boost, Mayhem tuned, etc... <<<<Broken Under Construction : BTR boost cam, sodium valves, titanium springs, 15% overdriven balancer, 80lb squirters>>>>
1969 MGB GT MKII Factory Condition
Old 05-27-2018, 06:25 PM
WVRigrat05's Avatar
Wound for sound
Mine got decent mileage with bad injectors, it’s returning the fuel to the tank not pushing it into the cylinders
Reger
