  #1
Old 11-22-2016, 06:18 AM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
Default Shop Cleaning
I have a couple unfinished projects that I need to finish and just took on another that is going to cost me more than my truck ever did.
I will update this list as I continue to find things hiding away:
Holset HC5A, cast compressor wheel, G-trim Turbine. $1500 OBO
I bought it as a new rebuilt turbo a few years ago, has sat on a shelf ever since.
HTT S482, FMW wheel, 87mm Turbine, Polished comp housing.$1300
I have .90 and 1.10 housings for it, if you want both then add $250. Turbo is used but is still in great condition, it spent 99.99% of its run time being choked by the small exhaust housing and limited to 52psi of boost.
Exergy 100% Over LLY Injectors. Used, built in 2009. $2000
Checked once in 2010 before I bought them, again in 2011 after I got the truck running, and have sat in the motor sealed up since late 2013.
Industrial Injection Double Dragon CP3, Prototype model. $1200
This is based off a dodge pump, built originally for Jess Spruill's race truck. I have it mounted as a remote pump with a II Flex line and a controller that Ben made for me. This pump has never skipped a beat for me. Price is just for the pump, but if the buyer is interested in the controller, HP line, and Wehrli A/C bracket mount with his polished wheel, I'll consider selling it all for $1900.
DPC Torque Converter, New since refresh in 2014, 3100 stall. $1100
For an Allison. To be honest, I have no idea what the parts specs are anymore. Phil always took care of me, and helped me out in a lot of pinches, as he does for so many other customers of his.
If my PM box fills up here, you can also email me at FreedomDieselNE@gmail.com for the fastest response.
Thanks,
Tim
__________________
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #2
Old 01-16-2017, 11:43 AM
juddski88's Avatar
Freedom Diesel
Default
Bump, also have 6 good 2007 lbz injectors, had 120k miles. I pulled one to have it tested and it was well within bosch spec. Selling the six for $600 plus shipping.
__________________
Thank you.
  #3
Old 01-24-2017, 04:14 PM
juddski88's Avatar
Freedom Diesel
Default
I'm lowering the price of the HC5A to $1,300 and the Double Dragon Pump to $1000.
__________________
Thank you.
  #4
Old 02-19-2017, 05:44 AM
juddski88's Avatar
Freedom Diesel
Default
Tax time. Bump
__________________
Thank you.
  #5
Old 02-19-2017, 06:58 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
List the HC5 on pulloff.com. G-trim are in demand for pullers
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #6
Old 02-19-2017, 07:15 PM
Fasttoys450's Avatar
Fasttoys450 Fasttoys450 is offline
Dmax
Default
Would you sell just 2 of the injectors
__________________
  #7
Old 02-20-2017, 07:19 AM
juddski88's Avatar
Freedom Diesel
Default
I won't split up the 100 overs. They were a matched set and should stay that way
__________________
Thank you.
  #8
Old 02-20-2017, 12:35 PM
Dmax
Default
Not the 100 overs the 6 lbz injectors
__________________
  #9
Old 02-20-2017, 05:06 PM
juddski88's Avatar
Freedom Diesel
Default
Yessir I'll split those up.
__________________
Thank you.
  #10
Old 02-20-2017, 06:03 PM
Dmax
Default
Pm sent
__________________
  #11
Old 02-23-2017, 08:01 AM
juddski88's Avatar
Freedom Diesel
Default
Sale - pending payment for the LLY injectors.
__________________
Thank you.
  #12
Old 02-23-2017, 11:06 AM
juddski88's Avatar
Freedom Diesel
Default
Quote:
Good recommendation sir, thank you.those guys are hungry.
__________________
Thank you.
  #13
Old 02-26-2017, 11:03 AM
juddski88's Avatar
Freedom Diesel
Default
I also found 4 full lbz/lmm Y-bridge assemblies, 2 lbz and 2 lmm egr cooler, 2 lly y-bridge assemblies, 3 lly egr coolers, several uppipes from all generations with the egr risers still intact, and some drivers side uppipes too.
Maybe a shop in California needs this stuff? Not sure how your emissions laws are hurting you guys out there
__________________
Thank you.
  #14
Old 02-26-2017, 11:10 AM
TheBac's Avatar
TheBac TheBac is offline
Default
I think Rick is still looking for egr uppipes, Tim. Might want to give him a jingle and ask if he wants them.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD
"Kleshay" -- 2000 C5 Corvette -- the toy
Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom You're already missed, at home and on the piano.
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #15
Old 03-01-2017, 07:46 AM
zf>allison's Avatar
zf>allison zf>allison is offline
you never had your car.
Default
Pm sent on 100% overs
__________________
04.5 single cab lly zf6 barely not stock.(the jalopy)
05 single cab lly zf6
Arp studs, welded water pump, 100 overs, dual fuelers, valair 1000 hp triple disc, danville efi live, fass 150, custom single s400 kit,
serious weight reduction
28x10x16 Hoosier slicks on pyos
Down on 2 leaves, t bolts gone.
best
10.91 at 129mph, 1.577 60 foot
dynoed 743 hp raceweight 5k with driver
Instagram-636zf6
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
