  #16
Old 10-10-2018, 07:34 PM
Henry95's Avatar
Henry95 Henry95 is offline
Thanks for all the info guys just trying to make sure I build something that isnít going to hinder suspension.
  #17
Old 10-10-2018, 07:36 PM
Henry95's Avatar
Originally Posted by malibu795 View Post
If it's a pavement princess it doesn't matter
Definitely not a pavement princes. Lol
  #18
Old 10-10-2018, 07:48 PM
malibu795's Avatar
malibu795 malibu795 is offline
Originally Posted by Henry95 View Post
With one end being a hiem wouldnít it cause wear a lot quicker and youíd feel it more then a rubber bushing?
They make boots for them to keep the diet out..those in the pic are for a car..
The shackle is setup like this and usually only one
I've ran hiem joints on both ends never had a problem..
Setup up wrong.... Mainly no pre-load it bucks hops and Carry's on regardless what bushings are at the ends
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
smooth seas never made a skillfull salior
  #19
Old 10-10-2018, 07:57 PM
Henry95's Avatar
Okay that makes more sense, except the last part. Lol. Are you missing a word or is it me?
  #20
Old 10-10-2018, 08:08 PM
malibu795's Avatar
Autocorrect...
Normal traction bars... I've seen buck hop ride rough and carry on, if setup is wrong (usually no axle pre-load or improper axle pre-load) regardless what bushings are at the ends...mainly referencing James comment about rough ride with heim joints
Adam
  #21
Old 10-10-2018, 08:17 PM
Chevy1925's Avatar
Heís thinking that if the springs are not under some kind of bind with the triangulated bar, the axle will still wrap or hop which isnít the case IF you have enough separation between the top and bottom bushings at the axle. Tire size and torque will dictate this separation distance like a 4 or 3 link. 8-9Ē would be plenty.
You want the triangulated bar as parallel to the ground as possible if you were to draw a line between the two axle bushings to the front single heim, you want that flat at ride height. Gives you 0 anti squat and lessens the bounce that it can induce. The triangulated setup is a much tougher setup as it reduces a lot more stress on springs but that means if not done right, it can ruin the ride or springs. Single bars under the axle are more forgiving in comparison
I would also highly suggest welding the housing to the axle tubes if you will sled pull with the triangulated one, it will put a ton of force on the center section
James
best time to date: 12.39
Tailgate Crew Member #4
  #22
Old 10-10-2018, 08:46 PM
Henry95's Avatar
Default Traction bar questions
So on a normal style trac bar do you need preload on any point? Probably what Iíll go with seeing as from what you guys are saying itís easier to setup and nicer ride. All I use the truck for is. Daily and pulling trailers/ fifth wheel trailers.
  #23
Old 10-10-2018, 09:04 PM
malibu795's Avatar
https://www.duramaxdiesels.com/forum...t=73366&page=2
Little to no proper preload had wheelhop
You commented to James
And agree as parallel to ground as possible for min anti squat
Adam
  #24
Old 10-11-2018, 01:43 PM
N2BRK N2BRK is offline
I listed where I bought my materials, etc. Hope this helps. https://www.duramaxforum.com/forum/s...yable-guy.html
08 LMM Crew 4x4
Dipper Trans/Mark's 68mmStg2R/40 over LBZ tips
Exergy 12mm
