  #31
Old 09-20-2018, 06:11 AM
Brent@LDS's Avatar
Brent@LDS Brent@LDS is offline
Originally Posted by CRAWLEN View Post
sorry i have been quite guys, been sorting stuff out with my shitter of an engine.
so its now getting a full rebuild, crank,rods,pistons,maincap studs, etc. so will be going for that nice 700hp max effort right away now.
so plan is from reading everyones comments is stick with the 100% with lbz tips as mark suggested.
and run a 10mm stroker pump.
so keen to get this together a running
The 100% injectors will take care of you very well and will give you room to grow if you need it.
Looking for LB7 Injectors?
Check these prices out!....
......... Lincoln Diesel Specialties .........
Phone: 920-361-7700
  #32
Old 09-20-2018, 06:19 AM
N2BRK N2BRK is offline
I say 12mm pump not 10mm, I buy once = cry once
08 LMM Crew 4x4
Dipper Trans/Mark's 68mmStg2R/40 over LBZ tips
Exergy 12mm
  #33
Old 09-20-2018, 07:46 PM
CRAWLEN CRAWLEN is offline
Gearhead
If the budget allows the 12mm I will get one haha at this stage all money is going in to the engine build then will be turbo and injectors. Then pump for sure
  #34
Old 09-29-2018, 04:56 AM
Gearhead
Originally Posted by MarkBroviak View Post
IF you do 100% make sure to have them done with LBZ tips not LMM's. LBZ's will run much cleaner and cooler than the lmm's will and you will be a lot happier with them.
About to buy injectors in about 2 weeks Mark, when you say lbz tips can i just bang an lbz injector in or do i need to go an lmm injector with the 100% tips ?
  #35
Old 09-29-2018, 10:55 AM
Nickracer9 Nickracer9 is offline
He’s saying get the 7 hole nozzle that the lbz’s run as opposed to the lmm 6 hole.
