Old 08-13-2019, 05:08 PM
DuramxMan's Avatar
DuramxMan DuramxMan is offline
Gearhead
Default Drive Shaft Loops
Wondering what everyone is running for driveshaft loops? Went to Crossville, Tn for ODSS and was told I need to have them when running slicks.
2004 Chevy 2500HD CC 4WD LB7, Studded Heads , DTS 67 mm turbo, 10mm Stroker Pump, 45 over injectors, FASS 150, MBRP 3" Downpipe, 4" MBRP Exhaust, DTS Built Trans, Suncoast 1073 Torque Convertor, Tie Rod Sleeves and Solid Centerlink, QA1 Shocks Best 1/4 mile 11.38 at 118mph 60 ft 1.611
Old 08-13-2019, 05:37 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
https://dirtyhookerdiesel.com/c-9324...aft-hoops.html
09 lmm ccsb ltz, moonshine, mpi s480 over 68mm vgt, sdp y bridge, BigDipper trans, 60 overs, 10mm pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165 w/sump, isspro guages, traction bars, 3" drop shackles, the list goes on...Big thanks to BigDipper!
01 lb7 red RC/LB [email protected] MPH, SOLD
01 lb7 Black CC/LB, SOLD
Old 08-13-2019, 07:58 PM
JoshH's Avatar
JoshH JoshH is offline
Do you have an aluminum or steel drive shaft?
06 Silverado 4x4 CC/SB
Old 08-14-2019, 04:07 AM
DuramxMan's Avatar
Gearhead
Aluminum rear and steel front
Old 08-14-2019, 04:53 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
I have DHD's full shields. I would venture to say they are the best available for our trucks and honestly installation was a breeze plus I know they aren't going to fail. I went steel as they were considerably cheaper. On a full out drag truck I could see getting aluminum.
K&D Service Inc
Call or Text: 906-284-0962
Providing a "one-stop-shop" for all of your automotive needs!
Current Rides:
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, F1 Diesel 275% Inj, Exergy 14mm Street Pump/LBZ CP3, Goerend AR Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, "Budget" Motor, Big Oil Cooling, Banks iDash 1.8 Monitoring System
Old 08-14-2019, 07:30 AM
coker6365's Avatar
coker6365 coker6365 is offline
Coker6303's ***** Daddy
I have the DHD Aluminum on the rear of each shaft and homemade steel loops from a cheap summit kit on the front of each shaft. If you don't want to spend the money on the DHD stuff, the summit kits will work fine with a little modifications. I think James has a thread on here somewhere with some pics on them.
2015 Denali CC/SB LML
2006 RC/LB LBZ, SXE472/87/1.0 & FI491/100/1.45, 250% F1 Injectors, Dual 10mm CP3, SoCal Built Engine, JoshH Built Trans, JoshH Tuning. 10.18 @ 140mph, 1487HP 2885TQ Corrected ATS Dyno. 2019 Diesel Power Challenge 1st Place
Big thanks to Josh Harris, Josh Chambers, and my brother Russell Coker for all the help with the LBZ.
Old 08-14-2019, 08:01 AM
JoshH's Avatar
The summit kits won't work on the rear aluminum shaft unless you section them to add a considerable amount of width. They barely fit with the significantly smaller steel shaft.
Old 08-14-2019, 08:09 AM
Chevy1925's Avatar
yeah the ones i modded were for steel driveshafts. the rear aluminum one aint gunna work with the summit hoop/
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
  #9
Old 08-14-2019, 09:56 AM
coker6365's Avatar
Ah, I didnt catch the alluminum rear shaft comment.
Sent from my SM-G965U1 using Tapatalk
  #10
Old 08-14-2019, 03:05 PM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
My DHD aluminum drive shaft shield after my drive shaft broke a couple weeks ago...
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
  #11
Old 08-14-2019, 04:45 PM
Bdsankey's Avatar
Attachment 49672
Wonder if that would’ve happened with the steel versions?
K&D Service Inc
Current Rides:
  #12
Old 08-15-2019, 04:51 AM
DuramxMan's Avatar
Gearhead
Zak did the shaft still come out or did it hold?
  #13
Old 08-15-2019, 05:09 AM
duramaxzak's Avatar
Wanna be puller!
It happened during a truck pull, when it broke the drive shaft yoke it pushed the slip yoke onto the output shaft and was stuck on there. So drive shaft didn't fall
all the way out, but drive shaft shield was laying in pieces on the ground.
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
  #14
Old 08-15-2019, 05:13 AM
duramaxzak's Avatar
Wanna be puller!
It ripped the 1480 yoke ears right off a custom built 5"x.125" aluminum shaft...
- ZAK
Special thanks to:
- Profab, Rick
- SoCal diesel.
