  #226
Old 08-29-2018, 06:53 PM
kiwilml's Avatar
kiwilml kiwilml is offline
Default
I had one for 56k miles and yeah I loved it too, it did seem to take def a little to regular and I didn't even tow with it... I would have over 100k miles on it now and no warranty so kinda glad I got rid of it when I did..
__________________
2016 Chevy LML CCSB.. HSP compound turbo kit with a Stainless Diesel 5 blade S475 over stock. Exergy 10mm cp3 conversion and still on stock injectors and transmission. 5" flo-pro exhaust and then EZ Lynk tuning by PPEI. Also have a 3 pod pillar post with autometer boost,lift pump fuel pressure, and egt gauges.
  #227
Old 08-30-2018, 09:51 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
My 16 has only used about 20 gallons in 30,000 miles. Those L5p suck down the hog piss...
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #228
Old 08-30-2018, 10:23 AM
lutzjk913's Avatar
lutzjk913 lutzjk913 is offline
Default
Quote:
For some reason I thought was deleted
__________________
Joe
2008 CCLB LT2 DURAMAX LMM
13.44 @ 98.69
456HP 925 TQ
2003 Regular Cab LB7
  #229
Old 08-30-2018, 12:49 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
use of the DEF is really going to be dependent on your right foot and driving conditions. You guys should know this . The cummins we had was 1/2 to WOT the whole trip and turning 2100-2700rpm running through decent amount of hills and elevation change. averaging 8mpg explains that.
My dad has 55k on his 15.5 LML and has put about 20-25 gal in but he doesnt race stop light to stop light and alot of his drive from and to work is cruising 50-55mph. So truck is running lower rpm, doesnt have a bunch of wind resistance, and engine isnt working that hard. Its jsut like you mpg for diesel. you can run a ton of diesel through your truck in 300 miles on a 34 gal tank or you can stretch it to 500-600 miles on the same tank.
So realistically the best way to show how much DEF you use would be to include how many diesel fills you have between each DEF fill. i would bet in that respect the variation between everyone wouldnt be that great but who knows, might learn something new. i dont feel mileage to tank refill is a fair comparison
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #230
Old 08-30-2018, 03:47 PM
Default
Quote:
Not the 16, 15 was, it started burning oil so I kicked it to the curb...
__________________
  #231
Old 08-30-2018, 09:01 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
How many miles on your 2015? I thought it was low mileage? Hard to believe it was using oil already. Another pos LML I suppose. My LLY still doesnít burn a drop.
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #232
Old 08-31-2018, 03:38 AM
Default
Quote:
Originally Posted by IOWA LLY View Post
How many miles on your 2015? I thought it was low mileage? Hard to believe it was using oil already. Another pos LML I suppose. My LLY still doesn’t burn a drop.
It was using it from the dig, unfortunately the truck had 276 idle hours and 17 miles when I bought it and I didn't catch it until it was too late. It is my theory that it was left running on the train during shipping. Rings never seated right, I had to delete it to figure out what was going on, it constantly regenned, it blue smoked bad. Took it to dealer, oil consumption was within GM spec so I traded it. Mileage was 68k when traded, it used the exact same amount of oil the entire time. I just caught it when I deleted bc of extended oil change intervals without regen. Low oil light would pop off, 2 quarts every time at 8k miles. 16 dosent burn a drop bc I broke it in like I do all my diesels, hook up to boat and drive straight to the FL Keys...
__________________
  #233
Old 08-31-2018, 05:22 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
Something very interesting to remember here. Never thought about that.
__________________
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
  #234
Old 08-31-2018, 08:31 AM
joshd472's Avatar
joshd472 joshd472 is offline
Default
Quote:
New 4 stroke outboards are the same way. Threads everywhere about them making oil. Specially Yamaha bc of their break in procedure. The cure is to run the piss out of them and have it propped so it can bounce of the rev limiter to seat the rings.
  #235
Old 08-31-2018, 12:03 PM
lutzjk913's Avatar
Default
Iím surprised it didnít run out of fuel
Every new truck we get has minimal fuel in it.
__________________
Joe
13.44 @ 98.69
456HP 925 TQ
  #236
Old 08-31-2018, 06:28 PM
Hambone's Avatar
Hambone Hambone is offline
Always learning
Default
Smokin I like your style!
__________________
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
  #237
Old 09-01-2018, 04:35 AM
Default
I'm sure it did run out of fuel, I talked with several people in the know, it happens more often than you would think. They use some vehicles thru out the day to warm up when cold and cool off when too hot. Guess mine was one of the warming stations when shipped...
__________________
  #238
Old 10-02-2018, 01:02 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default
Well she’s gone
__________________
03 reg cab. Low and slow
07 crew long classic- stolen
  #239
Old 10-02-2018, 01:18 PM
LBZ's Avatar
LBZ LBZ is offline
Default
5 months huh?
  #240
Old 10-02-2018, 01:21 PM
Chevy1925's Avatar
Default
Quote:
Originally Posted by clrussell View Post
Well sheís gone
so whatcha pickin up?
__________________
James
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
