Old 07-18-2018, 12:59 PM
davig's Avatar
davig davig is offline
Default Pvc?
I have a cali lb7 i know it has the egr. but does it also have a pvc? And if so how can i delete it, or is there a kit somewhere someone knows about?
2003 lb7 crew cab.5" turbo back exhaust and PPE boost increase valve. Lt265/70/17. Autometer gauges. Aih delete. bills custom intake stage 5. Creatures of the night efi live tunning. Ppe tie rods. 50 over injectors. .
Old 07-18-2018, 01:12 PM
ChrisPerry's Avatar
Lb7's are already vented to atmosphere.
And it's pcv. Pvc is a plastic pipe. lol
02 GMC 2500HD, EC/LB, LB7, 2wd, 6" lift, 35" tires. ds LML manifold, PPE 260 hp tune, boost valve, race plug, Airdog 165 lift pump, CAT filter mod, mechanical egt and boost gauges, SB intake, high flow turbo horn, ported turbo exhaust housing, kbd drop in wheel, Banks Bighead wastegate, egr blocked, intake heater delete, PPE downpipe, 5 " exhaust w/ cat delete, Mike L built trans w/ Goerend R converter. Levi's heat blankets
Old 07-18-2018, 05:54 PM
Bulldogr6's Avatar
Bulldogr6 Bulldogr6 is offline
FNG
Polyvinyl chloride pipe ? None on my truck! ;-)
Sent from my E6782 using Tapatalk
Old 07-19-2018, 01:00 AM
OregonDMAX's Avatar
NOT IN OREGON
He has a call emissions truck, it might not be vented to atmosphere
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret squirrel converter
supporting mods
Old 07-19-2018, 10:11 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
The cali trucks have a pcv. They come off of each valve cover join up and run down the side of the engine near the fcim / alternator. Can't recall if it dumps to the ground or if it is plumbed into anything
2008 Chevrolet 3500HD DRW LTZ
Old 07-19-2018, 10:46 AM
davig's Avatar
hahahaha I knew that it is a pcv i missed typed it.
Old 07-19-2018, 03:32 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
The cali emissions LB7 PCV dumps to atmosphere after the oil separator. Once EGR is blocked/removed, the intake will remain pristine with no further effort!
Old 07-19-2018, 07:01 PM
Chevy1925's Avatar
Wouldn’t that be all LB7 then? Mines that way and it’s a federal emission
James
best time to date: 12.39
Tailgate Crew Member #4
  #9
Old 07-19-2018, 07:04 PM
DAVe3283's Avatar
Yeah, that would be a simpler way of putting it. All LB7s vent the PCV to the atmosphere.
I'm just over here confusing everyone by over-complicating my explanation
  #10
Old 07-19-2018, 07:43 PM
Chevy1925's Avatar
Hahaha!
James
