  #16
Old 03-17-2019, 01:56 PM
Pure Diesel's Avatar
Pure Diesel Pure Diesel is online now
Randsburg Drifter
Thank you both for your responses.
Last question, I hope. So will any OS, for an 06LLY, work or do I have to have the one that came with it? If it has to be the original, I'll have to wait to hear from Russ then.
Thanks
White GMC 2003 2500HD D/A SLE/CC/SB 4x4] Bilstein 5100~Air bags~Autometer Gauges~33 BFG's~MBRP 4" Exhaust~SD tie rod sleeves~Cognito Braces~Kryptonite upper control arms DMAXSTORE XD TIE RODS~PPE high flow pick up~Fass 95 pump~Titan 52-gal.~Prodigy~New tranny 02/12/2015 Mike L. "Baby Frankenstein " w/Goerend converter w/ Mike L. tranny cooler and pump rub fix~6 speed tap shifter~Siege Engineering Anvil train horns(Very Loud)~LED headlights Hi/Lo
New injectors as of 03/12/2010 @ 80k miles
Injectors started going again at 115k. 07/01/2013
06LBZ engine transplant from Russ @ RPM Motorsports~No more Lb7 injectors to replace
  #17
Old 03-17-2019, 02:33 PM
torqued2dmax's Avatar
Originally Posted by gmduramax View Post
It doesnít have to be a stock tune but a stock calibration is needed.
Would it be less of a problem to buy a new Ecm and put the oem tune in it and just swap it out for the , you know what I mean !
05 CC/LB DRW LLY Allison
  #18
Old 03-17-2019, 02:44 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
Probably just needs to be the original OS, not original tune...
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
  #19
Old 03-17-2019, 02:52 PM
I see thanks !
  #20
Old 03-17-2019, 03:10 PM
gmduramax's Avatar
Shits broke
Thanks
Can you see what the OS is in the tune thatís in it? Then just pull one off of here that matches.
10.98@124mph
Tailgate Crew Member #1
  #21
Old 03-17-2019, 03:19 PM
Randsburg Drifter
The EFI live that I have is only for LB7's and it won't read the LLY/LBZ. I can't read anything about the system except for a few PID's and the VIN#. I'm going to have to go to someone and have them do it. Guy at SoCal Diesel is the closet to me.
  #22
Old 03-17-2019, 03:24 PM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
Get me the Vin# and I will give you the correct stock file for it.
06 LBZ "White Lightning" 2wd rclb Stockish Grizzly Locker 3.42 gears Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out TCTLMMStg2 Exergy 12mmcp3 1/8th 7.93@88mph 1/4-12.408@109.18mph
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
Proud and Honored to be able to say I'm the tuner for some of the Quickest and Fastest Dmax's out there! Stock motor Dmax pass with bolt ons and vgt(JKlennon - 9.96 @ 134.05 (5/11/18) Fastest Allison equipped Dmax power truck and first into the 5's with an Allison(Mike Graves Prostreet - 9.068 @ 161.19 (7/16/17)Fastest Crewcab with an Allison(Mike Graves 9.555@149.50(4-22-17) Fastest LLy and Fastest street Truck ever(bcdeutch731 C-10 - 8.395 @ 168.13 (9/22/16) Fastest LMM ever(Harbin_22 - 10.12 @ 138.12 (05/01/18)Fastest VGT turbo truck(Dmax02 (Alex) - 9.893 @ 139.62 (6/10/16) The #1 and #2 Fastest ZF6 trucks in the world (Ryan Pini LLY ZF6 10.674@132.4mph) #2 is with a stock engine(Jesse Rhodes 10.912@130.27mph)
  #23
Old 03-17-2019, 03:41 PM
Randsburg Drifter
The engine transplant VIN is 1GCHC29236E108487
The VIN in the window of the truck is 1GTHK23173F197425
  #24
Old 03-17-2019, 04:16 PM
DMax Junkie
Default stock file
Here you go sir! Stock file for truck untouched with the vin# of truck in it.
  #25
Old 03-17-2019, 05:00 PM
IdahoRob's Avatar
IdahoRob IdahoRob is offline
The problem is the Cali emission equipment looks at the vehicle vin, not the engine vin. This is why a dsp tune will not work. I don't believe a stock tune for a LLY/LBZ engine will pass because the OS doesn't match the vehicle(LB7) vin.
May have to have a LB7 OS matching your vin, modified to be able to run with the LLY/LBZ conversion.
Or just move, but not to Idaho...
Please email me with questions at rob@atptrucks.com
2002 GMC 9.36 @ 154MPH SoCal engine, Randy's 48re, Big Twin Diesel, Sold
2013 LML, twins, MIKE L @ Inglewood Transmission,
2018 L5P, Lift and tires, 14.65 @ 93mph
www.atptrucks.com
  #26
Old 03-17-2019, 06:10 PM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
That's certainly a possibility. Is there more leniency for an OS mismatch in the case of a "rebuilt" titled/registered vehicle?
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #27
Old 03-17-2019, 06:27 PM
gmduramax's Avatar
Shits broke
You can swap engines as long as itís the same year or newer. Not sure how to go about that process.
10.98@124mph
  #28
Old 03-17-2019, 06:40 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Greg is a nice guy Rob. Show some love.
Inglewood Transmission Service
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #29
Old 03-17-2019, 08:54 PM
rfletes79's Avatar
rfletes79 rfletes79 is online now
The vin in the ecm needs to match the vin on the dash. Also, the calibration/os needs to be a factory one from gm. The os doesn’t need to be from the year of the vin, just a factory gm one. If you load a factory tune in with all your emission stuff on and change the vin in your ecm to match the dash you should be good. Also DONT take it to a STAR station, their only goal is to fail everything that comes in the door. Look for a smog station that is not a star station. Only gassers are periodically required to go to star stations. Diesels are not required as of yet, for the occasional start test.
The ecm vin has to match because when the they scan the bar code on the renewal and the dash the tech compares it to the obd2 readout. If it doesn’t match, it can be percepted as if the obd2 readout is from a different vehicle then the scan (I’ve personally have had this issue with my truck).
Factory gm os with the right vin and all emissions on, no star and your good to go. If you need help with any of this stuff lmk, I can get you all you need and flashed onto your ecm if needed.
Rick
j
1970 Chevelle Duramax Hot Rod, '04 LB7/TH400-gear vendor, HTT 67.7 FMW, Wagler street intake, 65% S&S sticks, exergy 10 mil pump, SoCal AF3388, Valve springs, Push Rods, LBZ rods, cut LB7 slugs..... 10 sec cruzer :-)
2002 2500HD LLY 6 speed ally conversion
  #30
Old Yesterday, 05:31 AM
juddski88's Avatar
Freedom Diesel
Originally Posted by rfletes79 View Post
The vin in the ecm needs to match the vin on the dash. Also, the calibration/os needs to be a factory one from gm. The os doesnít need to be from the year of the vin, just a factory gm one. If you load a factory tune in with all your emission stuff on and change the vin in your ecm to match the dash you should be good. Also DONT take it to a STAR station, their only goal is to fail everything that comes in the door. Look for a smog station that is not a star station. Only gassers are periodically required to go to star stations. Diesels are not required as of yet, for the occasional start test.
The ecm vin has to match because when the they scan the bar code on the renewal and the dash the tech compares it to the obd2 readout. If it doesnít match, it can be percepted as if the obd2 readout is from a different vehicle then the scan (Iíve personally have had this issue with my truck).
Rick
That makes sense, Mass is nearly the same now in the last few years, except we don't have the same Smog requirements. And the emissions modules can give a status of "not supported" , just not "not ready" or failed or anything like that.
Thank you.
HTML code is On
