Old 10-11-2018, 12:12 PM
mechman3 mechman3 is offline
no such thing as too fast
Default Coolant leak back of engine
I have a coolant leak on the back side of the engine. It is sometime a 12" puddle other times a couple of drips. I took it into the stealer and they said the backing plate is leaking. I do not understand the construction of these motors but this seems odd. Can anybody please shed some light on this for me?
2005 GMC CC/LB
Grade C HG with ARP studs
3"MBRP Downpipe
EGR blocker plate
EFI Live by Starlite Diesel
Edge Insight CTS
Old 10-11-2018, 12:24 PM
c5fourj's Avatar
c5fourj c5fourj is offline
Occasionally moving quick
Could use some pictures of where the coolant is leaking from.
2006 GMC cc/sb
HSP s366sxe, w/ ppe up pipes, AFE intercooler,
5" FLOW PRO, fass 150, 72" trac bars
Overloads pulled, 2" drop shackles, torsion key bolts pulled, on 285/55/20
All Rare Parts front end, DHD brace
EFI live and built trans by Diesel Day Dreams
Old 10-11-2018, 12:30 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
The rear cover of the motors is a removable aluminum "plate" (really a complex casting, but only 1-2" thick) that adapts it to either a SAE bellhousing pattern (Kodiak Medium-Duty trucks) or the standard GM V8 bellhousing (normal pickups). The coolant comes in the left side, and crosses over to the right side, entering both halves of the block.
The rear cover off my motor:
You can see the two big circular ports with o-rings that seal to the block.
And mounted on the motor, you can see the flat coolant crossover tube, and the blanking plate on the right of the motor:
That blanking plate is a common source of leaks. Well, not common, but more common than the ports that seal to the block.
Old 10-11-2018, 12:34 PM
JoshH's Avatar
JoshH JoshH is offline
Which side?
06 Silverado 4x4 CC/SB
Old 10-11-2018, 12:59 PM
I believe it is the driver's side of the back of the motor. I will try and get some pics.
2005 GMC CC/LB
3"MBRP Downpipe
EGR blocker plate
Edge Insight CTS
Old 10-11-2018, 01:01 PM
Thanks for the explanation and pics they have opened my eyes.
2005 GMC CC/LB
3"MBRP Downpipe
EGR blocker plate
Edge Insight CTS
Old 10-11-2018, 03:07 PM
JoshH's Avatar
If it is leaking on the driver's side at the rear, I would check the oil cooler for coolant leaks and also check in the valley for leaks up there that are running down from up top.
Old 10-11-2018, 03:43 PM
DAVe3283's Avatar
X2, if you have a EGR cooler or turbo coolant line leaking, it could just run down the back of the motor like that. Those coolant hoses are pretty old at this point, and having one just spring a leak at this age isn't unheard of.
