  #16
Old 09-22-2017, 09:23 PM
malibu795's Avatar
malibu795 malibu795 is offline
I broke the OEM twist lock version long time ago..
Hopkins also make 4 bolts version that's plug in play to the OEM connector.. used it for a while till I started having issues with the OEM side of the connector then cut everything off..
I've put some serious tongue weight on this super hitch, upwards of 3500lbs, not to mention sled pulling with it.. LMM has yet to be hooked to a sled... Maybe next year
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
smooth seas never made a skillfull salior
  #17
Old 09-22-2017, 09:32 PM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is online now
Now thats a hitch , nice mods and thanks for pics !
05 CC/LB DRW LLY Allison
  #18
Old 09-23-2017, 05:44 AM
malibu795's Avatar
Not recommend needed to move both 4 miles
Adam
  #19
Old 09-23-2017, 08:10 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Oh my...
06 GMC 2500 CCSB SLT LBZ 4X4
  #20
Old 09-23-2017, 08:39 AM
ChrisPerry's Avatar
Why not do 1 at a time so as not to risk damaging truck or trailer?
02 GMC 2500HD, EC/LB, LB7, 2wd, 6" lift, 35" tires. ds LML manifold, PPE 350 hp tune, boost valve, race plug, Airdog 165 lift pump, CAT filter mod, mechanical egt and boost gauges, SB intake, high flow turbo horn, ported turbo exhaust housing, kbd drop in wheel, Banks Bighead wastegate, egr blocked, intake heater delete, PPE downpipe, 5 " exhaust w/ cat delete, Mike L built trans w/ Goerend R converter. Levi's heat blankets
  #21
Old 09-23-2017, 08:59 AM
Hambone's Avatar
Hambone Hambone is offline
Always learning
Haha same reason we take all the groceries in the house in one trip... we are men!
Those bearings are probably shot now if you did any sort of tight turn
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
  #22
Old 09-23-2017, 09:01 AM
malibu795's Avatar
Tandem 7k Trailer.
13k on deck roughly...
Neither going to hurt my truck or that Trailer, Trailer was maxed out though
Needed both bobcats to unload another Trailer and couldn't leave one unattended
Adam
  #23
Old 11-12-2018, 05:32 AM
SoCalMike's Avatar
SoCalMike SoCalMike is offline
Bringing this back from the dead. Has anyone fit a 285/70/17 spare tire in there with this Curt 15302 hitch. I want to get my spare tire out of the bed and in the stock location. I will be running a 4inch exhaust also if that make a difference.
  #24
Old 11-13-2018, 10:30 PM
1FastBrick 1FastBrick is offline
Highly doubt it would fit.
The stock 245/75/16 barely fits as it is. Maybe 1-2 inches from tread to hitch.
And if you have an aftermarket diff cover, It definitely won't fit.
  #25
Old 11-13-2018, 11:07 PM
I thought I posted in here when I did my install but I guess not. I had to modify my hitch on the passenger side to fit with the banks exhaust on my truck.
I can try and get pictures of the Spare tire in relation to the hitch during the day.
While it's better than the OEM hitch, I had some trouble with mine. Guess it slipped though quality control...
The other thing I don't care for is the Hook mounts in relation to the pin.
  #26
Old 11-14-2018, 06:30 PM
How does this work for you to be able to see clearance?
  #27
Old 11-14-2018, 07:26 PM
SoCalMike's Avatar
Thanks for the help and pictures. Rear end diff cover is stock so that shouldn't be an issue. Between your tire and mine it's about a 2 1/4 difference. So about 1 1/8 inch on each side of your tire. It's going to be super super close it looks like. I have a friend with the same hitch saying it will fit a 285/75/16. So my 285/70/17 will fit..... Hopefully. Lol
I just got a new magnaflow exhaust. Friend also said he has a magnaflow 4 inch exhaust and it fits. Super tight and hard to get the spare in but it fits.
So I went ahead and ordered the hitch and new exhaust. I have an old out dated Curt hitch (15521) that will be taken out. I don't even think you can fit a stock size tire with this hitch. Plan is to remove my mbrp 4 inch dumped exhaust, remove the old hitch, install the new one, install the spare tire winch and spare tire then install the exhaust so I can tweak it around the spare tire and hitch. Good luck to me. Haha
Thank you for the help I really appreciate it. I will let you guys know how it turns out this weekend.
  #28
Old 11-14-2018, 07:34 PM
SoCalMike's Avatar
Again thank you for all your help. I really appreciate it. My trailer plug looks like the same as yours, mounted exactly where your is. I'm crossing my fingers everything I bought works together. I have a feeling most of it will. From the pictures it looks like it should barley fit the spare tire. I see what you mean about the hole for the pin. Again I will report back after I install everything. Good or bad you will hear back from me.
  #29
Old 11-15-2018, 02:49 AM
FYI, The batch my hitch came from, The person running the laser didn't check there offset on the hole size. The Slots for the bolts where undersized. What should have been 1 hr at best to remove and replace took me all day.
Hope you have better luck.
  #30
Old 11-29-2018, 07:28 AM
SoCalMike's Avatar
I was able to make the hitch work with the 285/70/17 spare tire. The tire is up against the hitch and very close to the rear differential. But everything works as of now. I ended up using a latching strap on the driver's side to pull the tire away from the exhaust to give me even more room away from the exhaust pipe. I have driven about a couple hundred miles and everything is still good.
On a side note, the magnaflow exhaust I got to go with this set-up is not good. The first part of the instructions say to cut off a certain amount of pipe depending on what truck and configuration you have. Well it is completely wrong. I even called magnaflow and asked for direction because what the directions say to cut and what I am seeing are completely different. All they could say was cut off what we said in the directions and it's better to cut off less than cut off too much. After going back and forth for about 10 minutes and not going anywhere he told me to install it backwards working from the back of the truck to the front. To top it off he acted like I didn't know what I was doing and when I kept proving him wrong that's when he said to install it backwards, basically don't follow the instructions.
After about 6 to 7 hrs of messing around with it to get it to work, the tail pipe sections are not made right. The tail pipe either sits right under the overload leaf spring with about 2 or 3 inches of clearance making it hit each other when the suspension travels or I move it so it kinda clears but not the exhaust pipe is right up against the passanger shock and the tail pipe is up against the rear fender. I modified and cut off a little of the tow hitch corner to see if that helps and it doesn't. Even with the tire and hitch not there it still doesn't work. I ended up having to dump the exhaust right after it goes over the Axel to make everything work.
Magnaflow will not give me some money back or help me since I modified the exhaust pipe to make it fit even though I called for help and did what the technician and instructions said to do. This is the second magnaflow exhaust I have had and both of them did not fit good or correctly. For some reason I always associate magnaflow and quality together and that is not the case in my experience. I bout the exhaust kit from etrailer and they tried to help buy magnaflow is not willing to budge. The kit was shipped directly to me from magnaflow. I paid hundreds of dollars for something and it doesn't completely work like it should.
As of now I will not be buying any magnaflow products. Mbrp exhaust kits have always worked good for me so I will be sticking with them going forward.
Sorry to go off on a side note but i wanted to share my experience with magnaflow and hope I can help anyone else to avoid this.
