Old 07-16-2018, 12:42 PM
mopar440cu's Avatar
mopar440cu mopar440cu is offline
Duramax Newbie
Smile LML upgrade suggestions
Hi everyone!
I just picked up a 2012 Silverado 3500 4x4 WT with a duramax motor and Allison transmission with 37K miles and was wondering what would be the first mods you would suggest? This truck is not going to race or offroad. It is for pulling a 16' trailer for my aluminum extrusion company. I own a bunch of Cummins trucks, but never a Duramax so its a whole new ball game. I have ordered a service manual for it, but figured I could learn stuff from you guys also.
On our Cummins we start by installing gauges first then start getting rid of the junk lift pump and install AirDog165 's and put in a 1/2" fuel line. Then comes the bigger air filters and so on...
My questions to you is.
1-Is this the same basic steps as described above with these motors?
2-I know it has a CP4 fuel pump, but does it have a in tank sender? I am guessing an Airdog would help out with fuel delivery.
3-What would you suggest for air filter setup? Or leave it stock?
4-What type of tuner to get? LML has a EGR, Cat, DPF & DEF.
5- Should I delete all of these, LML has a EGR, Cat, DPF & DEF? Or just some? What kit to do this is best?
6- What about a throttle booster?
Thanks for any suggestions!
Old 07-16-2018, 03:13 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
I suggest a lift pump on any lml just for added filtration and helps fuel deleivery tremedously. Airdog 165 is a good choice.
Leave the Intake stock as it's not absolutely needed, although Idaho Rob did do a test with a s&b filter set up and it's gained some nice hp on a stock tune.
Deletes aren't really talked much around here, but get EFI live from reputable tuner and they will be able to help you.
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
Old 07-16-2018, 04:10 PM
snowman22's Avatar
snowman22 snowman22 is offline
The S&B intake made a noticeable difference on my LML.
2015.5 LML GMC Denali 3500 SRW 4wd CCLB 95k Miles
Mike L Trans, 4" FlowPro, MBRP Down Pipe, 30" FTE Resonator, S&B Intake, Twin Kennedy Pumps, Bilstein 5100, Poly U/LCA Bushings, Kryptonite Tie Rods, Edge CTS2
Old 07-16-2018, 04:16 PM
ripmf666's Avatar
ripmf666 ripmf666 is offline
Originally Posted by mopar440cu View Post
Hi everyone!
Lift pump is a greet add on. If youíre u have the funds full delete and cp3 swap is nice. I have most of the parts new I never used on my lml. Selling them all discounted and also can supply you with lift pump and tuning for your truck.
Name to come
2013 GMC Denali HD 2500 ccsb,100%stock,spray liner,B&W
Sold but not forgotten
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
11.53 @ 116.92 1.66 60's
Old 07-16-2018, 05:10 PM
mopar440cu's Avatar
Duramax Newbie
Originally Posted by ripmf666 View Post
Lift pump is a greet add on. If you’re u have the funds full delete and cp3 swap is nice. I have most of the parts new I never used on my lml. Selling them all discounted and also can supply you with lift pump and tuning for your truck.
What parts are we talking about you have? I’m a neophyte on Duramax, but learning.
You cam pm me if you want with prices.
Thanks!!
Old 07-16-2018, 08:29 PM
ripmf666's Avatar
What parts are we talking about you have? Iím a neophyte on Duramax, but learning.
Thanks!!
This link should take you to my post.
http://www.duramaxdiesels.com/forum/...archid=9898910
Name to come
Old 07-16-2018, 09:47 PM
Burn Down's Avatar
I would suggest reading this thread.
http://www.duramaxdiesels.com/forum/...ad.php?t=63908
04.5í CCSB ole blue, built trans, mpi twins
03í Reg Cab ZF 6
05í CCSB ole crappy, built eng, built trans, mpi twins
Old 07-17-2018, 12:38 PM
mopar440cu's Avatar
Duramax Newbie
It just tells me, "Sorry - no matches. Please try some different terms."
Have another site ,maybe?
  #9
Old 07-17-2018, 12:39 PM
mopar440cu's Avatar
Duramax Newbie
Thanks, I am trying to read it on my short break from the heat here.
  #10
Old 07-17-2018, 11:19 PM
ripmf666's Avatar
This should work itís the garage sale area. I have all the parts listed there.
http://www.duramaxdiesels.com/forum/...splay.php?f=15
Name to come
  #11
Old 07-18-2018, 05:59 PM
06gmc's Avatar
06gmc 06gmc is offline
Loud and Heavy
What are the internals on the LML holding up to?
2014 GMC Denali LML S&B AIR, SDP CP3 SWAP WITH EXERGY SPORTSMAN PUMP, PUSHER COLDSIDE AND CHARGE, 5 IN STRAIGHT PIPE, 165 FASS
BIG THANKS TO CORBIN!!
