  #1
Old 11-18-2006, 09:44 AM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default HTT LLY Turbo Kit Install Instructions:
Courtesy of Ben (DuraToTheMax):
http://www.dieseldrags.com/turboinstallpics.doc
Since the HTT is using the BD pedestal system, the BD LB7 instructions can help as well:
http://www.bd-power.com/pdf/manuals/...ax%20Turbo.pdf
Courtesy of BD-Power.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #2
Old 11-22-2006, 09:18 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
dang those are awesome instructions!!
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #3
Old 11-22-2006, 09:25 PM
The Neens's Avatar
The Neens The Neens is offline
BFD
Default
Quote:
Very detailed, thanks for doing that...
__________________
2007 GMC 4WD CC/SB...McRat EFI Live, Trans & Trans Cooler by Inglewood Transmission, SoCal Diesel, PPE, RKTMech
2002 Chevy 2WD CC Dually...McRat EFI Live, Trans & Trans Cooler by Inglewood Transmission, SoCal Diesel, PPE, RKTMech
Next Taps party on ??-??-??
The sooner you fall behind, the more time you'll have to catch up...
Team Arrogance Founding Member
The Gerbil Clubs founding Member#1
"Gerbil Trainer for the Stars"
  #4
Old 12-28-2006, 11:38 AM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default
Amendment to Ben's instructions: use the BD method for oiling, BD doesnt supply you with the fittings to run from the factory oil/cam journal. You must use BD aux supply directions.
  #5
Old 01-05-2007, 04:48 PM
<--- slippery roads
Default
I had an old version of the BD kit, which had oiling coming from the stock location. Thats how I setup my McRat/HT turbo and its still working fine from the stock location.
__________________
  #6
Old 01-05-2007, 10:12 PM
WolfLLY's Avatar
Making Chips
Default
I wasnt stabbing atcha Ben, I just thought I would give future peeps a heads up so they wont be like me saying WTF I missing parts.
Nice instructions btw, they helped a ton.
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #7
Old 01-10-2007, 03:27 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
those instruction are great, how long did the install take?
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #8
Old 01-10-2007, 03:53 PM
WolfLLY's Avatar
Making Chips
Default
4 hrs if you are speedy. Air tools, fast fabricator etc.
__________________
LB7 ECSB 4X4
  #9
Old 08-08-2007, 09:37 AM
That's better
Default
im just re-reading through the directions here before i get started
is it neccesary to remove the intake riser IF i already have the EGR silver cooler tube removed?
any other tips would be greatly appreciated
PS: Ben your instructions are very nice
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #10
Old 08-08-2007, 12:06 PM
WolfLLY's Avatar
Making Chips
Default
You might be able to work around it.
__________________
LB7 ECSB 4X4
  #11
Old 08-08-2007, 12:10 PM
<--- slippery roads
Default
how do you have the EGR up-pipe manifold blocked off?
Welding/bolting a plate cover on it will not work. It will vibrate and crack the little flex pipe.
__________________
  #12
Old 08-08-2007, 12:27 PM
That's better
Default
its been blocked with a thick blocker blate for the last 20 000 miles
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #13
Old 08-08-2007, 12:28 PM
That's better
Default
Quote:
thanks, if i have to take it off i will
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #14
Old 08-09-2007, 04:04 AM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default
Quote:
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #15
Old 08-09-2007, 09:11 AM
Turbotug's Avatar
Turbotug Turbotug is offline
BEER SLAYER
Default
It might be worth your time to find a stepped hose for the turbo outlet. It's probably at least 1/4" in diameter larger than the stock charger. I had one hell of a time trying to get it one.
You'll also run into a lot of "each truck is different" situations.
The first test drive makes it all worth it though!
__________________
Brandon
SunCoast
EFILive
HTT
588hp 1096tq
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
LLY HTT install Ben46a LLY 8 03-24-2007 07:14 AM
PPE GT42R LLY Turbo Kit is a serious contender! McRat Pacific Performance Engineering (PPE) Fullerton ca. (714) 985-4825 Dan Grant 22 01-16-2007 01:52 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
