  #16
Old 03-26-2009, 08:01 AM
WSUcowboy's Avatar
WSUcowboy WSUcowboy is offline
500 club baby!!
Default
I bought two off of Ebay for the same price, installed them last month, no issues as of yet! -Jeff
__________________
2002 DMAX/ALLI, CC/SB, RCD 6"w/35"'s,
OS#: 15186006
VERSION 2.0!!!
Mike L tweaked Suncoast 5 w/ 1057 rebuilt by Terry @ Precision.
MITUSA, AFE Stage 2, SD's Beefy Rods, Cognito braces, Henderson Supersteer, custom idler brace, Firestone bags, On-board Air, Vision HID's, MBRP Cool Duals w/6" tips.
550hp @Diesel Thunder '09 (Stock Turbo & Injectors, NO drugs!)
  #17
Old 06-21-2009, 10:30 AM
tomc983 tomc983 is offline
tomc983
Default
i had my truck at the dealer for a injector check and the mechanic went over everything else. he said the right front wheel bearing is goin so i brought the truck home jacked it up and there is no play. so i read this thread and saw that it said "You can tell if the wheel bearing is shot by jacking the truck up til the wheel is off the ground, grabbing the top and bottom of the tire and try to pry it in and out. ANY movement is wear. A stocker will not move. Ours were worn to the point of more than 2" slop at the tire with 50,000mi on the truck. You can drive pretty far worn bearings without fear of the wheel departing the truck due to the captive design of the unit." so if a stock wheel bearing is shot it wont move???
__________________
2003 chevy 2500 hd
4" MBRP
AEM brute force hd intake
cognito leveling kit + 285 rf10s
Wish list: guages, and a tunner
  #18
Old 06-21-2009, 10:33 AM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
If the wheel doesn't move, then it's fine.
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #19
Old 06-21-2009, 10:42 AM
Whitetail Addict's Avatar
Whitetail Addict Whitetail Addict is offline
Rockin' the stock tune
Default
Like Kat said, there will be NO play in the new GM unit.
I bought an aftermarket assembly after getting sticker shock from the price of the GM unit...big mistake. Installed the new aftermarket unit and checked it after it was all back together...it had more play than the wore out original unit I was replacing
I had to tear it back off, put the wore out one back on so I could drive the truck the next day, return the pos aftermarket one, and then go buy the GM unit and install that.
__________________
Brandon
'12 LML
'03 LB7
If you feel like everything is under control, you're not going fast enough - Mario Andretti
  #20
Old 06-21-2009, 10:45 AM
Kat's Avatar
Kat Kat is offline
Default
Quote:
Originally Posted by Kat View Post
Just bought 2 more that are OEM replacements for Blue $264. I will let everyone know what Pat thinks of them when the arrive.
http://gmc-car-parts.macautoparts.ne...=515058&page=1
Where they these? I bought these for Blue but Pat hasn't had time to install them yet.
__________________
  #21
Old 06-21-2009, 10:51 AM
SIKDMAX's Avatar
SIKDMAX SIKDMAX is offline
Highway Burnouts!
Default
Kat that is the "national" brand.... National Hub Assy company, should be fine.
Part 515058 PTC
__________________
Matt...2008 Chevy DMax CCSB 4x4 LTZ LMM
Carillos, Mahles, ARP 625s, SoCal Cam, Stage 1 Heads, 60% sticks, PPE Dual CP3, HTT 66SS/GT4718R Stainless Steel Twins, PPE High Flow Intake Manifold, Up Pipes and Headers. 6" MBRP single stack. Mike L. Suncoast 4 w/ 1057
  #22
Old 06-21-2009, 11:42 AM
Default
I honestly could not say Kat...it was over a year ago.
I looked back through my service receipts and don't have that one, I should have wrote the name down.
The problem was, the play was not noticable until the wheel was installed and you could get leverage on the assembly.
__________________
Brandon
'12 LML
'03 LB7
  #23
Old 06-21-2009, 11:44 AM
tomc983
Default
ok thanks i was kinda hoping it was goin when the dealer said it was cause i have a small vibration between 60 an 75mph and hoped that was the cause
__________________
2003 chevy 2500 hd
4" MBRP
  #24
Old 07-20-2009, 06:19 PM
05lly2500hd's Avatar
05lly2500hd 05lly2500hd is offline
(903)293-6026
Default
Looks like I'm gonna tackle this for the second time on the exact same wheel.
I changed the driver's front somewhere between 40k and 80k miles and now I"m on 118k and have play. I'm gonna have to try summit this time, sounds cheap. Just hope their product is not.
Thanks again.
__________________
MAD AMERICAN DIESEL PERFORMANCE, LLC
Amsoil lubricants, S&B intakes, AFE, EFILive, MBRP, Suncoast, MPI twins, EFILive tunes and more...
website will be up soon...stay tuned..
(903)293-6026
  #25
Old 07-20-2009, 06:23 PM
(903)293-6026
Default
http://www.summitracing.com/parts/WBI-515058/
This the correct one, huh? Bako?
__________________
(903)293-6026
  #26
Old 07-20-2009, 07:05 PM
Bako_Dmax's Avatar
Bako_Dmax Bako_Dmax is offline
GTO Slayer
Default
Ya thats it. Ive replaced both mine about 10k ago and they are holding up well so far.
__________________
2006 Chevy LBZ
MBRP exhaust, Shimmed FPRV, Blocked EGR
Homemade Lift Pump W/ Bypass
Homemade Pitman & Idler Braces
Tierod Sleeves
EFI Live
Built trans w/ triple disc
Homemade Twins S475 w/ 38mm gate
  #27
Old 07-20-2009, 07:23 PM
(903)293-6026
Default
Quote:
great thanks. Ordering!
__________________
(903)293-6026
  #28
Old 07-20-2009, 07:31 PM
TIM Z's Avatar
TIM Z TIM Z is offline
Screwed by 0087s
Default
This thread is new to me, Thanks for the write up Kat!,
I just did my first bearing last week,42,000 mi.
__________________
2007 CCSB 4x4 Duramax LT3 LBZ
M A STG III Allison- S.C. T-Case brace/Pump rub Fix
Precision Industries M L Race Converter
EFI LIVE V2 DSP5 ACID Tune by DIESEL ADDICTION
Twin Lift Pumps/ Race Valve
6'' T.C. Strong kit/Cognito Braces/SD sleeves.
some other goodies.
2000 ECSB Z71 -6.0 LQ4 BLOWN -TVS 1900 10 psi - Comp 226*-224*/ Dyno Tuned By TJ @ Baker Engineering/SS LT Headers/ RPM LVL VI 4L70E Billet output/ Precision 2600 Vigilante Stall. Hauls Ass
  #29
Old 07-20-2009, 07:53 PM
(903)293-6026
Default
yeah it's a great write up, i used it 3 years ago. Pics are awesome.
__________________
(903)293-6026
  #30
Old 07-20-2009, 08:43 PM
(903)293-6026
Default
funny, I just found an assembly on ebay for $32 less, exact same part number, but it's listed as National Bearing whereas summit is listed as Wheel Bearings Unitized...............
__________________
(903)293-6026
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
