  #31
Old 01-27-2009, 09:00 AM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default
Quote:
Originally Posted by TNRGreene View Post
That's a race valve in there also. How many shims should I use? What is the difference between an LB7 & LLY valve. I have 1 of each & I don't know how to tell tem apart
I dont think you shim a race valve, its either you install a race valve or shim the stocker
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #32
Default
How about this, plug the line, bottle hooked to the other side. Start truck & unplug CP3, fuel in bottle & a leak in the original line also
leak in a hard line too
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #33
Old 01-27-2009, 10:32 AM
Cougar281's Avatar
Cougar281 Cougar281 is offline
Default
I'm confused... Does this mean you had the bottle hooked to the nipple on the rail, and had fuel coming from both the FRPV and the other return line? I think fuel coming from the hose that gets unplugged from the rail for the test is normal, as that's a return to the tank which is shared by the "normal" return for the extra fuel.
__________________
'04.5 2500HD Silverado LT CC/LB, LBZ D/A Dark Grey
Metallic, 05+ HD Hood & Grille, 192k and counting
Mike L Trans built by ME.
EFILive, PPE Race Valve, KD Twin Lift Pumps & Billet Fuel Pickup, MBRP 4" "Cat-Back" T409 straight piped.
300.59' 3rd place first pull
Best 1/4 times:
Truck: 14.067 @ 96.29, weighing in at over 7200#
446.4RWHP/820.2RWTq
Car (95 Cougar 4.6L V8): 14.680 @ 94.00
"The FIRST weapon is the mind, all others are incidental."
"I'd rather be judged by twelve than carried by six."
  #34
Old 01-27-2009, 10:36 AM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Quote:
just the short hose Larry that connects the 2
Quote:
it is normal,But the hose is leaking and thats not normal
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #35
Old 01-27-2009, 10:53 AM
TNRGreene TNRGreene is offline
Kicked to the Curb
Default
Yes what Simon said
__________________
I don't carry a gun to look for or start a fight. I carry one to finish a fight I never wanted to be in.
  #36
Old 02-16-2010, 02:37 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
ttt
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #37
Old 06-03-2010, 01:30 PM
Gya0ma7ha's Avatar
Gya0ma7ha Gya0ma7ha is offline
From driving the truck
Default
Am i not seeing this or does the Lb7 not have a rubber hose like that, seems as though the end of the rail is connected to something with a hard line, not rubber hose.
__________________
2001 2500HD LT CCSB 4X4 LB7
SHE RUNS ON PRE-MIX
Gauges, lights, sound
305-55 R20 Terra Grapplers
6" Procomp set at 4"
EFILive-DSP5
Modded intake horn and BD Wastegate
Banks CAI, banks monster exhaust
431 HP
823 TQ
  #38
Old 06-03-2010, 02:25 PM
That's better
Default
Lb7 have a junction block on the ds of the y bridge in that junction block is where the relief valve is..... Follow that line off the back of the rail and u will see the juntion
if you do a seach you should see some pics
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #39
Old 07-05-2010, 07:23 PM
iranaround's Avatar
iranaround iranaround is offline
FNG
Default
what this one
  #40
Old 07-05-2010, 07:44 PM
That's better
Default
Quote:
Originally Posted by iranaround View Post
what this one
Pardon
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #41
Old 05-18-2012, 11:13 AM
tmm403 tmm403 is offline
FNG
Default
Great info. Going to try this test this weekend. Thanks
__________________
2006 Chevy Silverado ..LBZ..mbrp 5" turbo exhaust (no muffler) modified stock air intake, diablo predator, Big Dipper stage IV trans, Precision ML, Pump rub fix, Alligator trans lines, Autometer guages, Airdog II-165, Ready Lift leveling kit, 285/75 Nitto Dune Grappler, Bilstein shocks, Cognito idler and pitman arm braces, ppe tie rod sleeves, fingerstick, blocker plate, pvc reroute,air intake regulator blocked, Banks boost tube, All Amsoil fluids
  #42
Old 06-15-2012, 05:12 AM
surpriseduramax surpriseduramax is offline
FNG
Default Whats the difference
Quote:
Whats the difference in using a race valve or just shiming it? is it okay to run a race valve on the street for a dd?
  #43
Old 06-21-2012, 03:11 AM
That's better
Default
Quote:
Shims are cheaper......yes its safe IMO
personally i would shim before running a race valve JMHO
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #44
Old 06-21-2012, 05:09 AM
FNG
Default
do you know what is the difference is?
  #45
Old 06-21-2012, 07:19 AM
jc1843 jc1843 is offline
Default
Shimming the FPRV will still allow the high fuel pressure to bleed off, if the fuel pressure should spike.
The "Race Valve" is just a plug and will not bleed off high pressure if the pressure should spike. I don't think it should be run on the street- [My Opinion]
__________________
2004.5 LLY - EC-LB- LT - 64 gallon Aero tank, CAI, de-badged, MikeL-6 spd-TransGo, HD upgrade, 06 mirrors, gauges- Putnam XDR, shell, BU camera, Cabin Filters, GPS, Bluetooth, Sirius, PPE, LBZ-MP
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
