Old 12-26-2018, 05:44 PM
chrisuns's Avatar
chrisuns chrisuns is offline
Default l5p 220 denso alternator on a lbz
Does anyone know if the l5p Denso 220amp alternator will fit a lbz and if the pulleys match the belt off the top of their head?
2007 LBZ - Few go fast and handling parts.
Old 01-21-2019, 09:05 AM
gmc502 gmc502 is offline
I have the 220amp alt. in my 2016,,sure does look like it would fit.
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
Bdsankey Bdsankey is offline
Got the PN?
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18)
-Built Motor, Billet S475/87/1.00 T4, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans w/DEFEO 6 Pinion Planet, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch Reman Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, Beans Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
