Old 11-03-2019, 06:54 AM
Marshrat Marshrat is offline
FNG
Default Remote start question
When using the remote start, does the alternator charge the batteries without the ignition being in the on position?
Thanks
Warren
Last edited by TheBac; 11-03-2019 at 03:54 PM. Reason: copied question to stereo/electronics
Old 11-03-2019, 05:06 PM
$chultz38 $chultz38 is offline
Yes
Old 11-04-2019, 08:15 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
The way these trucks are wired is the alternator is hooked directly to the batteries (in the big red junction box near the power steering pump). The ECU controls the alternator, so as long as the engine is running, the ECU will command charging, even if the ignition switch is off.
You can always verify this with a multimeter. Hook the multimeter up to your battery, hold the hood sensor down so it can start, and remote start the truck. Be careful nothing gets sucked into the belt, etc. You should see the voltage come up to 13+ volts within a minute of remote starting the truck.
Old 11-08-2019, 08:53 AM
FNG
Thanks for the info.
Warren
