Old 10-09-2019, 04:21 PM
Turbo Performance's Avatar
Turbo Performance Turbo Performance is offline
Default New Color Options. Carbon Black and Graphite Gray
Hey everyone,
Have a couple new color options available. Moving forward these will be replacing the original coated black and silver blankets.
Though the originals will be available by request if trying to match a previous setup.
Blanket performance is every bit as good with these colors as they were before.
Shout with questions!
Levi
turboperformanceproducts.com
208)251-9141
Turbo/Manifold/Hotpipe Blankets
Old 10-09-2019, 07:47 PM
Burn Down's Avatar
New colors look good Levi When I get the single cab up and running Ill bring it up to you for some custom blankets on the turbo plumbing.
Albert
04.5 CCSB ole blue, built trans, mpi twins, 12.5X @ 108
99' Reg Cab, 1500 2wd, turbo 6.0, th400 build inprogress
05 CCSB Millennium Falcon, built eng, built trans, mpi twins, 11.51 @ 119 1.59 60
Old 10-10-2019, 05:34 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Are you planning on incorporating the loop-and-pull through method like these blankets show or the same mounting style as previous?
I'm going to end up needing a set once I get my LB7 back on the road (bearing damage so its getting new main/rod bearings, oil pump etc) with compounds. I do need to hit you up about what is going to be the best option for heat protection on the downpipe.
Current Rides:
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-Tuned by Starlite
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap, LML Oil Pump, LML Piston Cooling Nozzles, 2020 L5P Oil Cooler, Derale Aux Oil Cooler w/Fan, Banks iDash 1.8 Monitoring System
Old 10-10-2019, 09:25 AM
Sounds good, give me a shout when you're ready!
I prefer the anchors shown in the picture. In my experience they're a stronger fastener and put less stress on the blanket over time than the grommet style does. With that being said, I can do whatever a customer wants fastener or style wise.
Shout at me when you get closer to being ready and we'll spend a few minutes on what will work best for you.
Levi
208)251-9141
Old 10-10-2019, 06:44 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
I need 2 small turbine T4 blankets for my LS
"OldManTan"
04 SC/SB 1500 Dart 427ci, AFR 6 bolt heads, twin 80mm turbos, TH400 8.91@155 so far..
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel deleted by Fleece
Tailgate Member #1 I prefer the backdoor
Old 10-11-2019, 08:00 AM
Small? I figured you had went big on literally everything this time around. Build really looks good dude. Send me over some specs on what you need or a measurement and I'll get you hooked up.
Levi
208)251-9141
